Possible problems? BT Wholesale.
Necrotix
Hey guys,
Just a quick message to the plusnet guys to ask if there is any fault recorded or work being carried out recently?
Last couple of days when browsing the internet, I'd randomly get a green and white BT Wholesale page popping up. Re-connecting (and therefore, switching gateway) seems to fix this.
Thanks.
Fixes: 62
Re: Possible problems? BT Wholesale.
Put your phone number in here to check http://status.zen.co.uk/broadband/
Necrotix
Thanks for that link. I'll bookmark that for future use.
No faults found apparently. Strange. Anyway, if it continues to happen i'll raise a fault ticket with Plusnet to see if they can make any sense of it.
Cheers!
