Possible packet loss?
networknovice
Long time PN customer, never had any major connection issues in that time, and still don't have problems with general web usage.  However I'm a bit of a novice to online gaming.  Recently got into Rocket League, my connection has been fine.  But for the last couple of weeks I've had rubberbanding/lagging a few times per 5 minute match.  I've reinstalled the game, but the problem exists still.
I did a bit of basic googling and used the command ping plus.net -n 300 ; here are the results:
Ping statistics for 212.159.8.2:
Packets: Sent = 300, Received = 295, Lost = 5 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 21ms, Maximum = 439ms, Average = 29ms
Is this out of the ordinary and worth raising a support ticket for, or just one of those things?  I've changed sockets, microfilters, and used a wired connection to the router.  One thing that may or not be related is that my speed test results have gone up 50% from previous months.  Also I don't seem to have any gaming usage in my usage stats, don't know if that affects things.
silkysean
Re: Possible packet loss?
Yep I've been getting this the last few days too. Something is wrong at the server end I'm certain
Fixes: 162
Do you experience problems with any other online services? What happens to your ping at that point? Wired/wireless connection?
 Chris Parr
 Plusnet Staff
silkysean
I've replicated the OP's test. I'm getting similar results, although not as bad. Still bad enough to effect my online gaming which is the whole reason I have broadband!
Packets: Sent = 300, Received = 297, Lost = 3 (1% loss),
Minimum = 20ms, Maximum = 62ms, Average = 22ms
For fault finding purposes I am based in Hawkinge, Kent.
DWslider
Experiencing same problem, Hampshire
silkysean
Kind of glad in a way it's not just me it's happening to. How does it appear for you? Gaming? Browsing? Do you have Steam?
Fixes: 162
Can you try and not spread your issues over multiple threads please, it makes it much more difficult to keep on top of what's going on.
 Chris Parr
 Plusnet Staff
silkysean
I'll stick to this one. You can close my other one.
DWslider
Steam less affected than most but for example OW/LoL it shows as a freeze on all action on screen, a disconnection warning flash (never actualy disconnecting) and then the action catching up to current, spikes last from 5-20 seconds and have no pattern. My ping is fine if not excellent and download speeds are not experiencing issues, however the constant loss makes the service not fit for a touted service.
silkysean
Yep same here. Ping and download speeds are great but have random spikes of packet loss
networknovice
Chris, Thanks for responding.  I don't have any issues with streaming or web browsing.  I haven't really been doing any other online gaming that requires fast response so I don't know if any other games are affected.  I've tried both wired and wireless connections, with similar results when gaming.
Fixes: 162
Might be worth having a read of Bob's post here: https://community.plus.net/t5/Fibre-Broadband/Continual-intermittent-dropped-packets/m-p/1384464#M50...
 Chris Parr
 Plusnet Staff
networknovice
Thanks for posting the link.  I've tried restarting a few times.  Each time the ping test has better results, but still not perfect.  As others are posting the same issue, and an update was provided, at least it's not just my connection.  I'll keep an eye on others' posts to see if the issue is fully resolved.
Fixes: 86
Guys, provided a bit of an update here.
Also worth pointing out that pinging our website is not likely to be a good reflection of the situation as explained here. Better to use something like pingbox1.thinkbroadband.com.
