Possible Profile Reset Required
cressa
Had a forced disconnection on Sunday, since reconnecting my internet speeds both up and down have been reduced.
1. Best Effort Test: -provides background information.
Download  Speed
11.2 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.2 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 17.33 Mbps
Upload Speed
0.98 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.98Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Could a profile reset correct this and if so can this be arranged plea Coolse
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Possible Profile Reset Required
Your profile seems fine, it's at 17300 which is exactly what I'd expect based on the sync speed.
Are those speed tests via wired or wireless connections? Can you try a single disconnect/reconnect and see what the speed is like then?
 Chris Parr
 Plusnet Staff
cressa
Hi did a reset and everything appears to have returned to normal.
Thanks for your help Smiley  Smiley
FAQ
Results Image not loaded
Download  Speed
16.22 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 16.22 Mbps
IP Profile for your line is - 17.46 Mbps
Upload Speed
1.01 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 1.01Mbps
Plusnet Staff
Plusnet Staff
Fixes: 159
Who did a reset? Nobody looked at your account apart from me today (unless it's not the account linked to this forum username?).
Ah sorry, misread *you* did a reset.
 Chris Parr
 Plusnet Staff
