Possible Profile Reset Required
- Possible Profile Reset Required
19-01-2016 1:41 PM
Had a forced disconnection on Sunday, since reconnecting my internet speeds both up and down have been reduced.
1. Best Effort Test: -provides background information.
Download Speed
11.2 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 11.2 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 17.33 Mbps
Upload Speed
0.98 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.98Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Could a profile reset correct this and if so can this be arranged plea 8)se
Download Speed
11.2 Mbps
0 Mbps 21 Mbps
Upload Speed
0.98 Mbps
0 Mbps 0.83 Mbps
Message 1 of 4
(753 Views)
3 REPLIES 3
Re: Possible Profile Reset Required
19-01-2016 1:45 PM
Your profile seems fine, it's at 17300 which is exactly what I'd expect based on the sync speed.
Are those speed tests via wired or wireless connections? Can you try a single disconnect/reconnect and see what the speed is like then?
Message 2 of 4
(460 Views)
19-01-2016 5:42 PM
Hi did a reset and everything appears to have returned to normal.
Thanks for your help
FAQ
Results Image not loaded
Download Speed
16.22 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 16.22 Mbps
IP Profile for your line is - 17.46 Mbps
Upload Speed
1.01 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 1.01Mbps
FAQ
Download Speed
16.22 Mbps
0 Mbps 21 Mbps
Upload Speed
1.01 Mbps
0 Mbps 0.83 Mbps
Message 3 of 4
(460 Views)
19-01-2016 6:18 PM
Who did a reset? Nobody looked at your account apart from me today (unless it's not the account linked to this forum username?).
Ah sorry, misread *you* did a reset.
Message 4 of 4
(460 Views)
