Possible Outage 12/4
- Possible Outage 12/4
Re: Possible Outage 12/4
12-04-2013 10:35 PM
I have just posted an issue with setting up a new router and the problems I was having maybe this outage rather than my router setup?
12-04-2013 11:03 PM
I trust PlusNet will pass on BT's root cause analysis, explaining how such an outage can be so widespread!
12-04-2013 11:06 PM
Quote from: Tabbycat I trust PlusNet will pass on BT's root cause analysis, explaining how such an outage can be so widespread!
They usually are, When things go wrong they dont generally go wrong on a small scale... Last year i remember Edinburgh Exchange had issues, which was affecting me, based in the midlands^ - BTs network is a weird yet wonderful thing
What probably happened is a drop in connectivity between PN <===> BT for whatever reason, and thats what caused the issue (Thats a wild stab in the dark)
Regards
13-04-2013 1:27 AM
We've closed the service status.
13-04-2013 3:55 AM
Yes O2 customers are being transferred to sky.
Quote from: Matt_2k34 With all due respect, unfortunately [Censored] happens.
Been with plusnet for years, rarely have issues - my FTTC modem router had been connected solidly for over 90 days. The line im posting from now has been connected over 60 days. I only ever reboot them to speed the routers up a little.
Bare with folks - I know its a bit OH MY GOD when you move into a company and you experience a problem. However I'm sure it'll be sorted asap
Also isnt Be/O2 going to Sky?
Regards
13-04-2013 9:49 AM
As Poster Matt..2k34 says trouble happens, things break down...such is life.
If you are unluckly enough to be on the end of a cable theft incident then you will be without phones or broadband for around 8 to 10 day: I know it's happened to me.
If it's a big cable theft or the thieves have seriously damaged the associated infrastructure then you are looking at 2 weeks downtime.
http://www.ispreview.co.uk/index.php/2013/04/bt-apologises-for-two-week-broadband-and-phone-outage-i...
I would describe broadband as akin to the early stages of the motor car.
Some worked, some didn't, many worked only some of the time.
Those who had an interest in 'car things' got them to work the best.
It took at long time before a car was something you got in, turned the ignition and it worked every time.
When broadband has been around for as long as gas/electric/water I'm sure it will be as reliable!
13-04-2013 10:22 AM
Quote from: chrispurvey This issue has now been resolved. It was caused by an issue with node in Reading, we don't have any further information at the moment.
Well I hope in due course, we will receive a more detailed explanation. For a start, looking at the Broadband Usage graph showing the time in question (also see attached), only one Gateway seems to have dropped. Secondly, because there is nothing posted by BTw that appeared on Zen or AAISP or on BT Business Status for the time Plusnet customers lost service nor an MSO for that time unless this was the issue .... the only immediately obvious connection being the clear time. When you read through the supposed updates to that issue, it's evident that there is sloppy and unprofessional reporting by BTw. I'm guessing that the pre-existing fault resulted in the need for a card change, in which case BTw should have advised ISP's ahead of that, so adequate warning could have been posted - that a large number of customers would lose service for about half an hour. Considering that this was peak time, BTw really have no excuse.
13-04-2013 10:27 AM
Quote from: sp1ke Back again now.
This happened to me last Friday afternoon as reported on here on another thread.
I've just migrated from Be and so far not impressed at all.
Two outages in two weeks, lower sync and higher pings.
This type of outage does not affect sync with the exchange. If you have a problem with your line to the exchange, your service can be affected whoever your ISP. This is probably best addressed in your other thread.
13-04-2013 10:33 AM
Quote from: x47c I would describe broadband as akin to the early stages of the motor car.
Well said! Couldn't have put it better myself. Trouble is that, although some of you guys here seem to get off on delving into the entrails of the motor car (aka PC) , many of us just want to use it for getting from a to b (i.e. actually doing real jobs) !
13-04-2013 10:44 AM
That's because many of the customers who have been here for up to 15 years, originally signed up for "Force9" (before it became Plusnet). Back in the day "Force9" was the ISP of choice for internet and PC enthusiasts who wanted to tinker and get the most from their connections.
Unfortunately over time, the original innovative products got diluted, features disappeared with each new product, and now Plusnet is just another low cost consumer oriented supplier that happens to have a great traffic management system - when it isn't broken by all the recent/ongoing network problems !
13-04-2013 11:06 AM
Quote when it isn't broken by all the recent/ongoing network problems !
I wonder just how small is the % of customers were affected last night? Down here in God's country my connection has been as steady as a rock since early October 2012, when I converted to fibre.
13-04-2013 11:52 AM
Ta PN
13-04-2013 1:28 PM
I experienced the outage last night and just assumed it was a return of previous problems and, after several reboots to no avail, suggested to SWMBO that we leave it off for 10/15 minutes and then retry.
After that time it was back up and running so thought no more of it - didn't even think of checking Service Status.
Forum Moderator and Customer
13-04-2013 1:36 PM
15-04-2013 9:41 PM
