Portal password fault
mar7t1n
Is there a general fault with the portal. My password has stopped working to access the Members Centre. I would think it's me but I know someone else who can't get in either.
James
Re: Portal password fault
I've just checked and mine seems to be working absolutely fine.
Would you be able to manually delete your temporary internet files that relate to the portal to see if this helps?
mar7t1n
Yep that fixed it. Not sure what happened, but good old clear everything and start again worked a treat.
