Portal down? (25/8)
Fixes: 153
Portal down? (25/8)
Was OK earlier, can't seem to connect to it now - anyone else seeing this?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
cactusj
Re: Portal down? (25/8)
Yeah, it says my username and password is incorrect - is this the same for you?
working here but slowly but login is failing, Invalid username or password. Please try again.
21cn on pcl-ag01
edit: just logged into the website ftp sever, so my pw/name is working there
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 153
Just tried to refresh  and it's coming up totally blank on any page I've bookmarked.
intravone
same here can't login to the portal
says incorrect login and password
Fixes: 58
Tried a Force9 and a Plusnet account and failing authentication on both.
Customer and Forum Moderator.
acarneiro
Oh, good.... Glad it's not just me. Was wondering if my acount had been hacked and teh password changed or something....
SpendLessTime
Aspiring Hero
Fixes: 54
Sad
Plusnet account and cannot log into the portal either, saying incorrect login and password.
Fixes: 62
Login failed
login is working again for me
Fixes: 74
We had a problem with a couple of our back-end portal servers around that time that I suspect was related (ref: 82623).
Plusnet Products Team
Fixes: 153
thanks bob Smiley
