Portal Login
- Portal Login
- « Previous
- 1
- 2
- Next »
Re: Portal Login
13-12-2007 12:16 PM
Re: Portal Login
13-12-2007 12:25 PM
We currently have a small number of customers experiencing the same problem regarding portal login and that is being worked upon via the aforementioned problem ID.
Whilst we fully appreciate the annoyance of not being able to access the system as you would desire whilst this problem is being investigated unfortunately there is very little our support teams can advise other then to check on the status of the problems for you.
we have 3 levels of problem - 1 being the highest and 3 the lowest and your problem is currently assigned as a level 2 problem, but as with all problems there any many stages our teams have to go through to make sure the problem is investigated as much as possible and that when the issue is resolved it will fix the problem without it reoccuring or causing problems to any other service. You can see a little bit more about priority problems via the following weblink
http://www.plus.net/support/service/problems/index.php?supporta=priorityproblems
We will continue to check problem ID 47394 for you and when we have more news we will let you know.
When I follow the link to the priority problems page, it quite clearly shows that there are currently no priority problems. So if this particular problem is not a priority, then there should be some manpower available to fix it, as they are not working on any priority problems. Or have I missed something? Is there another page which gives similar information about non-priority problems?
Re: Portal Login
13-12-2007 1:18 PM
Re: Portal Login
14-12-2007 9:50 AM
We would like to inform you that your Help Assistant Question [ 23465368 ] has now been returned to the Customer Support Centre pool. A member of our Support Team will investigate your issue as soon as possible.
Again?
Re: Portal Login
14-12-2007 10:33 AM
A few more users have now reported that they are affected by this issue. As such this has now been raised to a p1, and is already assigned to a member of our development team.
You can track this here.
Apologies for the delay in getting this sorted for you.
Re: Portal Login
14-12-2007 4:55 PM
This should be fixed for you now, can you confirm?
Re: Portal Login
14-12-2007 5:25 PM
Invalid username or password. Please try again.
Re: Portal Login
15-12-2007 11:54 AM
Re: Portal Login
15-12-2007 12:32 PM
Sory about the hassle, I'll see if anyone's down in QA now though I suspect not. If that's the case it'll get picked up on Monday.
Re: Portal Login
16-12-2007 8:58 AM
Re: Portal Login
16-12-2007 12:52 PM
Hope that helps,
Re: Portal Login
16-12-2007 1:08 PM
- « Previous
- 1
- 2
- Next »
