Portal Branding bug - in domain transfer tool
- Portal Branding bug - in domain transfer tool
24-01-2008 6:22 PM
Wasn't sure where to post this, but figured here was reasonable (but not perfect!)
On the Portal in the "Domain Admin" section, on the "Transfer in" page, it asks you for the
"Admin contact email:"
which defaults to:
"postmaster@<username>.plus.com"
Yet this is logged in to a Force9 account!!! I suspect that this is a remaining bug from the Portal harmonisation project.
Presumably this should default to:
"postmaster@<username>.<brandingurl>"
Hope this helps
Mike
which defaults to:
Hope this helps
Mike
Message 1 of 3
(1,013 Views)
2 REPLIES 2
Re: Portal Branding bug - in domain transfer tool
25-01-2008 8:36 AM
I'll get a problem raised on this when I've confirmed it.
Raised as 49698
Raised as 49698
Message 2 of 3
(351 Views)
25-01-2008 4:18 PM
Thanks Colin,
Fortunately I noticed it when using the form, as my username wasn't too long, but if someone has a longer username, they might not see that it is wrong, and might submit it assuming that the default is correct.
Mike
Mike
Message 3 of 3
(351 Views)
