Port forwarding settings
- Re: Port forwarding settings
11-10-2014 3:11 PM
Hi
I've new to plusnet, what I need help with is the correct settings for port forwarding or better still anywhere on the internet with a step by step way of setting it up, so I can view my CCTV from my mobile phone
Message 1 of 3
(717 Views)
2 REPLIES 2
11-10-2014 3:17 PM
Moved here on the assumption that you are using a Plusnet router. If not which router is it
Which mobile phone is it and are you intending to use a particular app to access the feed
Message 2 of 3
(414 Views)
11-10-2014 3:23 PM
Hi
Sorry for posting in the wrong section, yes it is a Plusnet router Technicolor TG582n router, my phone is Samsung galaxy S5, the current app i've got on the phone is KYeye, which i used when i was with origin broadband
Message 3 of 3
(414 Views)
