Port forwarding by remote access
- Re: Port forwarding by remote access
20-06-2014 1:20 PM
Port forwarding stops intermittently on my remote router. I presume that this is because the modem might have reset itself to default, deleting the port forwarding settings saved on it. This happens on a regular basis, which means I cannot access the server remotely. How do I reset port forwarding (remotely) without having to be at the actual site to re-programme the router every time. Better, how to I stop the router defaulting to stopping my port forwarding set-up? PS my router is a Technicolor 582n
Message 1 of 4
(756 Views)
3 REPLIES 3
20-06-2014 1:48 PM
I'm just doing some digging re that, hope to let you know ASAP.
That shouldn't be happening, it would be worth a reset to factory defaults manually. If that doesn't help it may need replacing.
Quote How do I reset port forwarding (remotely) without having to be at the actual site to re-programme the router every time.
Quote how to I stop the router defaulting to stopping my port forwarding set-up?
Message 2 of 4
(444 Views)
20-06-2014 4:14 PM
Quote from: PhoenixGiraffe Port forwarding stops intermittently
That sometimes happens when the device is on a static LAN IP address.
PF tends to work best with the device IP assigned via DHCP -- set "always use the same IP address" in the routers network settings for the device.
This is no help at the moment but the next time you're at the router you could set it to allow remote access.
http://npr.me.uk/remote.html
Message 3 of 4
(444 Views)
20-06-2014 5:16 PM
Message 4 of 4
(444 Views)
