Port forwarding Technicolor TG582n Driving me mad
- Re: Port forwarding Technicolor TG582n Driving me...
27-02-2013 4:52 PM
Things I tried so far.
1) setup static ip add on my PC via manual config the ip I used was outside the dhcp address range and setup static ip add for my PC on the router by checking the always use the same IP address in my devices
2)in game and application sharing picked create a new game or app picked a name manual entry
Picked my port range then added it to my static ip.
No joy also tried many variations of this with no joy.
I've even disabled the firewall to open all ports and they are still blocked.
I've payed £40 for this router and it is no good to me if I can't forward the ports.
Pls help me out.
Re: Port forwarding Technicolor TG582n Driving me mad
27-02-2013 5:11 PM
What port info did you put in or what's required?
27-02-2013 5:16 PM
27-02-2013 5:47 PM
27-02-2013 5:51 PM
Quote from: tooter 1) setup static ip add on my PC via manual config the ip I used was outside the dhcp address range and setup static ip add for my PC on the router by checking the always use the same IP address in my devices
Did you try those separately or together? Try without the manual IP config on the PC.
27-02-2013 6:01 PM
27-02-2013 6:04 PM
I would just drop it and buy a decent router, I use a netgear N300, others recommend Asus's and TP-links just look in this forum.
27-02-2013 6:06 PM
HTH
27-02-2013 6:10 PM
Mind you I had static ip's setup and it went and issues a DIFFERENT ip address when I rebooted my "server" (laptop) when I first tried that router, that was one of the things that moved me to buy a DECEIT router.
27-02-2013 6:17 PM
Andy
I'm trying to setup any ports so I can integrate sabnzbd with my nzb.in account
All ports I try and open show as closed on pf.com
Ejs
Both was tried separately
Pwatson
I allready tried that but thanks
Hairy biker
I have tried a cople of other routers but can't get it to connect to the fiber connection
I have a net gear n150 will this connect to my fibre line?
27-02-2013 6:25 PM
27-02-2013 6:32 PM
http://www.o2help.co.uk/router-port-forwarding/
Don't use a static IP in the devices own network settings, use "automatically obtain a IP address"
In the routers network settings for the device, tick "always use the same IP address"
27-02-2013 7:07 PM
@hairy biker
I was told that as long as router supported pppoe it would work is that incorrect?.
27-02-2013 7:10 PM
27-02-2013 7:14 PM
