Port Forwarding in Technicolor TG582n
dcdgupta
is it possible to do Port Forwarding in  Technicolor TG582n.  I need to set up port forwading for port 8080 where I am running a Tomcat Webservice.
I have got a static IP address on the machine where I am running the webserver.
I have explored the Game & Application Sharing menu but I did not find any option to link the internal IP address to the port.
Please provide some guidance
Fixes: 311
Re: Port Forwarding in Technicolor TG582n
you need to take the option 'Assign a game or application to a local network device' then assign away..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
dcdgupta
This is the 2nd time I am having to post the reply... The earlier one was lost . Hopefully will not raise a duplicate issue.
Thanks for your reply. Could you please give some more details or post a link on how this is done.
This has 2 textboxes
1) Game or Application and
2 ) Device.
Where should I enter the portnumber and Internal IP address ? Is there a way for providing port Translation ?
dcdgupta
Alternatievely , Can I use my old DLINK modem instead of the one provided by PLUSNET ?
