Port Forwarding for Port 443
- Port Forwarding for Port 443
07-04-2015 10:15 PM
Having trouble port forwarding HTTPS traffic.
Have read this post - http://community.plus.net/forum/index.php/topic,127469.0.html/, but even with uPNP disabled, http://www.canyouseeme.org/ is still stating that port 443 is closed.
Can anyone help any further?
Many thanks.
Many thanks.
Message 1 of 4
(953 Views)
3 REPLIES 3
Re: Port Forwarding for Port 443
08-04-2015 10:30 AM
Do you already have a server running on port 433 on the PC you've forward that port to?
canyouseeme needs the server to be active on that port before it can give a positive result.
Message 2 of 4
(684 Views)
08-04-2015 2:56 PM
Quote from: npr Do you already have a server running on port 433 on the PC you've forward that port to?
I did wonder whether I'd need something running - I don't at present, the idea of opening up 443 is in preparation for a server deployment. Is anything I could quickly provision, to test connectivity to 443 from the Internet?
Many thanks.
Message 3 of 4
(684 Views)
08-04-2015 4:08 PM
Portforward's "PFPortChecker" does the job, but it needs to be run from the same machine which you've PF'd to.
Unfortunately it looks like you now get other stuff bungled in with the download, I don't know the implications of that so use at your own risk.
http://portforward.com/help/portcheck.htm
Alternatively install and run a basic web server on the target PC for testing, there's a few simple free ones about.
Message 4 of 4
(684 Views)
