Port Forwarding Help - CCTV
Michael995
Hi
I am hoping somebody can help me, I need to open two ports on my router, these are 9000 and 80, I am struggling to do this.
Basically I have a cctv system that is connected to my router, if I am on the wifi network I can view the CCTV on my phone, if I am on any other wifi or 4g network it does not connect to the DVR, I am guessing I haven't opened the ports correctly.
Could somebody offer some help please, plusnet technical support have told me they don't support port forwarding!
Re: Port Forwarding Help - CCTV
What router do you have, the process will be different between models?
Michael995
It's the 2704n.
Fixes: 57
