Port Forward Foscam IP Cam with the Plusnet Hub One Router
gc2020
Hi.
I'm trying to connect my Foscam IP cam with the Plusnet Hub One router. However, I could not access the camera outside of the home.
I did register for the static IP. However, when ever I enter the static using a browser, nothing happened. Is there anything i've missed out?
Fixes: 101
Re: Port Forward Foscam IP Cam with the Plusnet Hub One Router
Presumably you are trying to access the IPcam externally using your static IP and correct port number.
Maybe the facility you are accessing from is blocking the port.
Customer and Forum Moderator.
gc2020
Yes i did. Strangely up till now nothing happen.
I even tried using a no-IP application and only have access if i'm using the home wifi using the fix IP 192.168.1.000:6969.
If i'm correct the static IP and DNS would be like this: 212.00.000.000:6969 (000 is assumed a number).
Now i'm out from home. Though I try to access the static IP, it did not direct me anywhere.
Fixes: 101
Is your static IP definitely up and running?
Foscam IPcams usually use something like port 81 or 88 by default.
I presume you have altered it for security reasons.
gc2020
Should be. Please see the attached image below when i checked the connection setting.
Fixes: 101
When I was setting up a Foscam camera I configured the Foscam app on my phone with the wifi turned off.
This made it easier to test the router configuration.
I don't use the Hub One unfortunately.
gc2020
Yes, it should be running and i've doubled check with the customer service on phone.
In addition, I also assigned my static home IP within the foscam setting. This is to prevent it from constantly changing. For example: 192.168.1.154:6969
However, the static IP i bought from plusnet does not actually work (i.e. direct me to an error page). For example, if i typed 202.99.9.999:6969 (presume my static ip: 202.99.9.999)
Browni
Aspiring Hero
Fixes: 45
@gc2020 have you set up port forwarding in the Hub One?
Advanced Settings -> Firewall -> Port Forwarding
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
gc2020
I tried connecting using both LAN and WIFI to coonect with my foscam app (via android). However, it wasn't a success. Therefore, i had to the setting using my PC.
gc2020
I did. I'll show you the print screen when i'm back home, later on.
gc2020
Please see the images below. I've tried.
In addition, since i switched to a static IP by paying plusnet and detect it (image: what is my ip). Using this IP i tried putting in the broswer with and without the port (e.g. 202.50.000.000:8609), and nothing happen.
Did i miss anything?
gc2020
Please see the image above of the settings made in my foscam and router @Browni @Strat.
