Port Forward Foscam IP Cam with Plusnet 2704n Router
tthjkn
Can anybody explain how to setup an IP camera with the Port Foward menu?
It doesn't appear that any cameras are listed in the pre-defined Games/Application drop-down list.
Any help appreciated,
Thanks,
Howard
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 29
Re: Port Forward Foscam IP Cam with Plusnet 2704n Router
I made this short guide about doing port forwarding for Xbox, just replace the ports I used here with the ones you need for the cameras
http://community.plus.net/forum/index.php/topic,147117.msg1294995.html#msg1294995
 Paul Tarr
 Plusnet Network Operations
