Port 25 blocked
gtaylor30
Port 25 blocked
It appears as though port 25 has become blocked on one of my referrals acounts who I support. What can be done to resolve this ASAP?
Graeme.
Re: Port 25 blocked
This is usually due to antivirus or firewall upgrades being applied incorrectly (generally by the program, not the end user). It's usually worth reinstalling and then reupdating the software, when I've had this problem (I use AVG free) this has solved it.
Hope that helps,
gtaylor30
Re: Port 25 blocked
Cheers mate, will try that.
gtaylor30
Re: Port 25 blocked
No Dice, uninstalled AVG completely, reset and nothing. As this is applying to both external mail accounts and Plus Net Accouns, I am guessing it must be due to the connection. OE is being used so is throwing up all sorts of errors, generally 0x800ccc6f which is mail transaction failed error codes. Please advise.
Fixes: 9
Re: Port 25 blocked
I suggest you try testing using telnet which may give you a better picture of what's happening:
Tutorials & FAQs: Servers: Telnet as a Diagnostic Aid
The part you need is headed Checking the SMTP server
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
gtaylor30
Re: Port 25 blocked
Tracked it to something else entirely, all sorted now, thanks for your help.
