Poor upstream sync
- Poor upstream sync
Poor upstream sync
15-10-2012 9:32 AM
Hi
I've been getting a few resyncs in the last week, not unusual as I am on a long line. Downstream sync usually stays around 3Mbps. However, recently the upstream sync has been badly affected, on one occasion as low as 64Kbps after resyncing. Can anyone suggets a likely cause bearing in mind that the downstream sync is unaffected? Noise, faulty filter, router on the way out? Quiet line test is noise free.
Message 1 of 9
(1,073 Views)
8 REPLIES 8
Re: Poor upstream sync
15-10-2012 9:38 AM
When you find out tell me as I have the same intermittent problem
Does the resync occur when the phone is left to ring
Message 2 of 9
(640 Views)
15-10-2012 10:23 AM
No link to the phone ringing at all, Oldjim. The resyncs sometimes happen in the middle of the night.
Message 3 of 9
(640 Views)
15-10-2012 10:44 AM
In which case I can't be of any help as mine always occurs when the phone rings so presumably the ring voltage is upsetting things
You could try a different filter
Message 4 of 9
(640 Views)
15-10-2012 10:50 AM
Good suggestion, I'll try that when I get the chance.
Message 5 of 9
(640 Views)
15-10-2012 12:05 PM
I can see from your recent history of upstream sync speeds that on one occasion it was at 64kbps. It looks like it was a one-off and it is back to your normal sync now.
How are things at your end?
Message 6 of 9
(640 Views)
15-10-2012 12:42 PM
From my experience it is highly intermittent and the upstream sync can drop to anything between 360kbps to 64kbps but the thing to watch is the noise margin. If it drops to 6dB on a resync then there is a problem
The actual sequence is that due to a burst of interference or cross talk between the upstream and talk frequencies the upstream errors to increase to the point where it loses sync. If the resync happens after the interference has stopped or reduced you will get full upstream speed but perhaps with a low noise margin
I can always see the upstream errors jump while the phone is ringing but not sufficiently to cause a resync
Note that on ADSL1 the reported upstream noise margin never changes unless there is a resync but on ADSL2 uncapped it does and this is on 21CN in both cases
Message 7 of 9
(640 Views)
15-10-2012 12:55 PM
Hi Chris
All back to normal now and hopefully it will stay like that for a while. From past experience the problem will recur in a couple of weeks though.
Message 8 of 9
(640 Views)
15-10-2012 2:01 PM
Let me know if/when it does and I'll run a few checks on your line to see if there's any noticeable difference, also keep an eye to make sure no other electrical devices internally are on during that time that aren't normally.
Message 9 of 9
(640 Views)
