Poor upload speed
- Re: Poor upload speed
Poor upload speed
20-07-2014 1:18 PM
I'm currently trying to backup my entire photo collection to cloud storage but upload is painfully slow at 0.30 Mbps (speed tested with no other devices on network, firewall & antivirus disabled and connected by Ethernet)
I believe you can request the upload speed to be uncapped but I am concerned that this might effect download speed as some mention might happen and as this is a more one off exercise I would prefer download speeds were given priority usually.
Does anyone have any experience regarding this?
I am 805 mtrs away from the exchange if that helps, someone on another forum said it might have an effect.
Message 1 of 9
(1,326 Views)
8 REPLIES 8
20-07-2014 1:33 PM
The quick way to check is to post your router stats - noise margin, speed and attenuation
However if your distance is correct then any reduction in download speed will be very marginal
Message 2 of 9
(699 Views)
20-07-2014 1:44 PM
Thanks Oldjim, does this help?
Message 3 of 9
(699 Views)
20-07-2014 1:48 PM
It does
Your upload is already uncapped
Can you post the full results of a speed test - it doesn't really matter which one as you should be seeing upload speeds around 900kbps
This is a quick one http://www.mybroadbandspeed.co.uk/
In addition please post the results of a BT speedtest further diagnostics as the upload IP profile just might be screwed up
Message 4 of 9
(699 Views)
20-07-2014 2:01 PM
Ok, that's interesting.
It's showing 17671 download, 567 upload (and that was without disabling firewall & anti virus again)
Maybe it was the Ookla speed tester at fault?
Message 5 of 9
(699 Views)
20-07-2014 2:03 PM
That is still low
Can you try the BT speedtest Further diagnostics - ignore all the preamble
Message 6 of 9
(699 Views)
20-07-2014 2:26 PM
Ahhh, It's my fault, I connected the Ethernet cable and thought I'd disabled the wireless, evidently not.
I re-ran the my broadband speedtest and now show 1009 Kbps upload
BT is showing 17.7 Mb download, 1 Mb upload
I take it that is about the best I can expect?
Sorry about that Oldjim, but thanks so much for your help though, much appreciated
Message 7 of 9
(699 Views)
20-07-2014 2:31 PM
Yup that is about the best you can get although I have no idea why the upload is so badly affected when on wireless
However you might like to consider a better router - others on here will throw in their opinions as the one I have got works fine as the main computers are wired and the tablet and phones seem to work OK around the house
Message 8 of 9
(699 Views)
20-07-2014 2:39 PM
Yes the wireless does seem poor considering the laptop is about 5 ft away from the router.
I usually use my iPad these days and don't have many problems however.
Having re-run the speedtests a couple more times they do vary, just got a 567, an 866 and a 950 upload. It seems to vary quite a bit. I'm not too sure how accurate these tests are.
The Technicolor router has always been pretty good as far as I'm concerned, so much better than my previous Belkin. I will probably look to upgrade at some point though when funds allow. Thanks for the tip.
Message 9 of 9
(699 Views)
