Poor speeds
- Re: Poor speeds
Poor speeds
09-01-2013 11:50 PM
Any thing i can do
Re: Poor speeds
10-01-2013 11:10 AM
Just checked your line and you've been connected for over 40 hours and your line profile on our side and BTs is at 17300 so there's nothing there that could be slowing you down. Is it any particular server or site that's slow to download, and is it all the time? Also what does a BT speed test show (http://www.speedtester.bt.com) for both your download speed and your line profile?
Re: Poor speeds
10-01-2013 8:51 PM
anything else i can do,and what are the actual speeds i'm meant to be getting i know i wont get 15mb
anything else i can do ?
Re: Poor speeds
10-01-2013 8:55 PM
Quote from: Whlzibos when i play a simple game like minecraft on my pc i get lag nearly every second and goes on until i get disconnected which is really annoying
Do you mean that your whole PC is slow whilst you're using playing Minecraft?
It could be bad drivers for the wireless card/adapter, or another device in your PC such as the graphics adapter (particularly if it only occurs when playing Minecraft).
Re: Poor speeds
10-01-2013 8:55 PM
Re: Poor speeds
10-01-2013 9:06 PM
Re: Poor speeds
10-01-2013 9:08 PM
Quote from: CX
no my pc isnt slow its internet related lag,i can play it normally i play gta iv with little lag so i think i can play minecraft without pc lag
Re: Poor speeds
10-01-2013 9:14 PM
its Microsoft so i believe this is the fastest ill actually get
Re: Poor speeds
10-01-2013 9:15 PM
1929KB/s = 15.8Mbps.
(1929 * 1024 to get Bytes per second, then * 8 to get Bits per second, then /1000 to get Kilobits, then /1000 to Megabits)
Re: Poor speeds
10-01-2013 9:20 PM
Quote from: CX Multiply by 8 to convert Bytes to bits.
1929KB/s = 15.4Mbps.
wow i did not know that i changes the setting on speedtest.net and im getting 2mb now,then its my upload speeds that is the problem
i dont think half of the people dont know the difference
Re: Poor speeds
10-01-2013 9:22 PM
Re: Poor speeds
10-01-2013 9:38 PM
Can a member of staff increase the upload limit plz
Much appreciated
Re: Poor speeds
11-01-2013 11:48 AM
Re: Poor speeds
11-01-2013 2:42 PM
Im on extra 60gb now and my line speed is 18 it says its going to change to 8??
Thanks for your time
Re: Poor speeds
11-01-2013 2:51 PM
