Poor speeds on MIL's connection
- Poor speeds on MIL's connection
20-11-2015 11:14 PM
Hi Plusnet,
I am visiting my mother in law (username 'scarolan') this weekend and was rather taken aback by how slow her broadband service is. She says it has been like this ever since signing up (a month or so back). By all accounts there were a whole host of issues even getting her line in but that is all water under the bridge now (hopefully) and so it would be appreciated if you might be able to provide some assistance with this.
The sync rate reported by the modem is 1152/288 down/up which struck me as rather low - should it be higher at this property? The BTW speed test result is 1.08Mbps/0.09Mbps down/up - attempting to run 'Further Diagnostics' gives an error stating that the 'Performance Tester is currently unable to run a speed test'. Other stats from the modem have been included below.
The line and master socket are new and whilst the modem is usually plugged into a nearby extension (also newly installed by BT) I have plugged the modem straight into the master to run speed tests etc. No alternative modems or filters are available to test.
I have raised a fault via the Member Centre and so perhaps that is all that needs to be done however I thought I would raise a query here in case you can assist. Unfortunately I am not local and will be leaving tomorrow and so there may be little further I can do at this end. Moreover, she may find dealing with anything technical difficult. However, with both the service and router being provided by yourselves, and the new line/socket/extension being recently installed by BT, I am hoping that between the two of you this can be sorted - assuming of course that these speeds are lower than would be reasonable to expect.
Thank you in advance for any help you might be able to provide!
Regards,
Mathew
Regards,
Mathew
DSL Connection
Link Information
Uptime: 0 days, 2:54:55
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 288 / 1,152
Data Transferred (Sent/Received) [MB/MB]: 12.96 / 238.00
Output Power (Up/Down) [dBm]: 11.5 / 11.1
Line Attenuation (Up/Down) [dB]: 7.5 / 10.5
SN Margin (Up/Down) [dB]: 31.0 / 48.0
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 8 / -
Loss of Signal (Local/Remote): 1 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 10 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0
Message 1 of 9
(1,778 Views)
8 REPLIES 8
Re: Poor speeds on MIL's connection
21-11-2015 12:01 AM
Quote from: MJN The sync rate reported by the modem is 1152/288 down/up which struck me as rather low - should it be higher at this property? The BTW speed test result is 1.08Mbps/0.09Mbps down/up - attempting to run 'Further Diagnostics' gives an error stating that the 'Performance Tester is currently unable to run a speed test'. Other stats from the modem have been included below.
That looks like the connection is on a 1Mbps fixed speed service. Based on the stats you posted I see no reason why an ADSL (or if available ADSL2+) service shouldn't work fine. Have you checked what the BT availability checker at https://www.dslchecker.bt.com/ gives for her phone number?
David
Message 2 of 9
(688 Views)
21-11-2015 12:06 AM
Thanks for your input Spraxyt. The checker gives the following:
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date
ADSL Max Up to 8 -- 7 to 8 Available
Fixed Rate 2 -- -- Available
Message 3 of 9
(688 Views)
21-11-2015 9:38 AM
Message 4 of 9
(688 Views)
21-11-2015 10:06 AM
Well that seems to be the answer but if it was a self install just check the filtering is correct depending on the master socket
http://bt.custhelp.com/app/answers/detail/a_id/40231/~/check-your-wiring-and-set-up
Message 5 of 9
(688 Views)
21-11-2015 10:19 AM
Quote from: Matthew Can you send me her username?
It's in the OP.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 6 of 9
(688 Views)
21-11-2015 10:21 AM
Matthew is on the case - thanks everyone for your assistance. It should hopefully be sorted Monday.
Message 7 of 9
(688 Views)
29-11-2015 5:21 PM
To follow up; the connection appears to be now working as expected. Walking my MIL through a speedtest suggests a ~6Mbps download rate.
Matthew - Out of curiosity can you confirm what the issue was and how it came about?
Message 8 of 9
(688 Views)
30-11-2015 9:43 AM
Message 9 of 9
(688 Views)
