Poor speeds and getting worse
- Re: Poor speeds and getting worse
15-05-2013 8:33 PM
Hi all,
When I signed up with plusnet I was told I would get 53.9meg download and 15.7meg upload +/- 1meg
However, when installed I only got 37meg download and 7 meg upload. Slowly over the last couple of months its got worse and now I get 33 download and a paltry 4.96meg upload. This is less than a third of the upload speed and 20meg less than the download speed I should get.
Its very annoying and I do feel a bit cheated - I could appreciate if it was a little bit slower but not such a lot.
I connect via a direct network cable and I have tried bypassing the router and going straight to my PC with a PPPoE connection but the speed is the same.
I've run the BT test and this shows 33.87 max acheviable for download and 20 meg max achievable for upload.
Message 1 of 4
(1,005 Views)
3 REPLIES 3
15-05-2013 9:49 PM
A DC Team member could check you are provisioned on the correct product tomorrow.
Message 2 of 4
(544 Views)
16-05-2013 1:01 AM
sounds like they might be traffic shaping you peter.
Message 3 of 4
(544 Views)
16-05-2013 12:27 PM
Hi peterb99,
I've checked over your connection and your line is provisioned on the 80/20 product. I can see that you sync speeds are currently below your estimate.
I'd suggest raising a fault via http://faults.plus.net so we can investigate this.
If you need any assistance with this please let me know.
Message 4 of 4
(544 Views)
