Poor speed
StuMac
Poor speed
My other half has unfortunately been disconnecting the router when speeds have dropped or it wasn't being used for long periods, this has caused our current speed to now become a max of 0.8Mbps.
Please could someone from Help/Support look into resetting the line so we can get a usable speed back? Any help with this would be greatly appreciated.
Thank you.
Fixes: 160
Re: Poor speed
I've requested a reset and this should happen within the next few hours.
 Chris Parr
 Plusnet Staff
StuMac
Re: Poor speed
That will be great, thanks Chris.
StuMac
Re: Poor speed
It didn't seem to make any difference at all really so I bit the bullet and bought a new router. Will the reset still be effective and the speed increase again over time? If not, is there any possibility that it could be reset again please?
Sorry for the hassle but any small increase in speed would make a huge difference to us as we live 'out in the sticks'.
Many thanks.
Stu
Fixes: 160
Re: Poor speed
Unfortunately not, we can only reset a line on 20CN once every 10 days. It may be that you see the speed improve again over the next few days however.
 Chris Parr
 Plusnet Staff
StuMac
Re: Poor speed
Ah ok, well thank you for your help.
