Poor speed
- Re: Poor speed
Poor speed
28-10-2015 8:18 PM
My other half has unfortunately been disconnecting the router when speeds have dropped or it wasn't being used for long periods, this has caused our current speed to now become a max of 0.8Mbps.
Please could someone from Help/Support look into resetting the line so we can get a usable speed back? Any help with this would be greatly appreciated.
Thank you.
Thank you.
Message 1 of 6
(866 Views)
5 REPLIES 5
Re: Poor speed
29-10-2015 12:03 PM
I've requested a reset and this should happen within the next few hours.
Message 2 of 6
(548 Views)
Re: Poor speed
29-10-2015 7:12 PM
That will be great, thanks Chris.
Message 3 of 6
(548 Views)
Re: Poor speed
05-11-2015 1:46 PM
It didn't seem to make any difference at all really so I bit the bullet and bought a new router. Will the reset still be effective and the speed increase again over time? If not, is there any possibility that it could be reset again please?
Sorry for the hassle but any small increase in speed would make a huge difference to us as we live 'out in the sticks'.
Many thanks.
Stu
Many thanks.
Stu
Message 4 of 6
(548 Views)
Re: Poor speed
05-11-2015 4:35 PM
Unfortunately not, we can only reset a line on 20CN once every 10 days. It may be that you see the speed improve again over the next few days however.
Message 5 of 6
(548 Views)
Re: Poor speed
05-11-2015 6:49 PM
Ah ok, well thank you for your help.
Message 6 of 6
(548 Views)
