Poor speed and performance
- Poor speed and performance
20-03-2015 5:55 PM
y speed has gone from just over 1 to .7 which I find un aceptable as very little works now
Home
Services
Settings
Site Map
System Info
Broadband
LAN
Firewall
Logs
Diagnostics
Link Test
Link Monitor
DSL
IP Utilities
NAT
Syslog
Resets
DSL Diagnostics - Training History
Physical Line 1
General Information
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 8128 kbps
Downstream Atten. at 300kHz: 68.2 dB
Uncancelled Echo: -13.0 dB Ok
VCXO Frequency Offset: -20.8 ppm Ok
Final Rx Gain: 29.9 dB Ok
Excessive Impulse Noise: 0 Ok
Downstream Required Impulse Noise Protection: 4
Downstream Impulse Noise Protection: 0.64
Downstream Delay of Latency Path: 4.00 ms
Upstream Impulse Noise Protection: 0.94
Upstream Delay of Latency Path: 4.00 ms
Framing Mode ATM
Training History
Downstream Upstream
Time Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Mode Vendor State Exit Code Echo VCXO Rx Gain
2015/03/01 06:09:10 GMT 1 1952 1964 1532 1532 6.1 6.0 67.7 17.3 6305 196207 0.71 4.00 448 644 12.0 12.0 31.5 11.9 171 359 0.94 4.00 G.DMT Annex A Alcatel 241/104 ERR_LOS_LIMIT -18.7 -17.6 29.9
2015/03/17 17:23:40 GMT 1 1568 1584 764 764 9.2 3.0 67.5 16.8 96801 728868 0.59 4.00 448 656 12.0 12.0 31.5 11.9 2684 10605 0.94 4.00 G.DMT Annex A Alcatel 241/104 ERR_LOS_LIMIT -18.6 -20.8 29.9
2015/03/20 08:04:35 GMT 1 928 948 1064 1064 9.2 13.0 67.9 15.7 956 21207 0.73 4.00 448 684 13.0 13.0 31.5 11.9 422 1997 0.94 4.00 G.DMT Annex A Alcatel 241/104 IDLE_REQUEST -15.8 -22.2 29.9
2015/03/20 17:43:56 GMT 1 1440 1440 1020 1020 9.0 9.0 67.2 16.8 879 7056 0.64 4.00 448 696 14.0 14.0 31.5 11.9 100 663 0.94 4.00 G.DMT Annex A Alcatel 240/104 N/A -13.0 -20.8 29.9
Bitloading
0000000456667778777777665544440000000057775675057868875666425777777777725767767767666655504555545544434423323222222222000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
0 16 32 48 64 80 96 112 128 144 160 176 192 208 224 240 256
Notes
Time Time of last update
Max1 Max. rate at start of connection
Max2 Current or final estimated max. rate
Max3 Current or final estimated max. rate without INC
Mgn1 Noise margin at start of connection
Mgn2 Current or final noise margin
DLY Downstream Delay of Latency Path
These are the details and the bt tester will not work as previously reported by some members
Home
Services
Settings
Site Map
System Info
Broadband
LAN
Firewall
Logs
Diagnostics
Link Test
Link Monitor
DSL
IP Utilities
NAT
Syslog
Resets
Physical Line 1
General Information
Framing Mode ATM
Training History
Downstream Upstream
Bitloading
Notes
Message 1 of 6
(1,280 Views)
5 REPLIES 5
Re: Poor speed and performance
20-03-2015 6:00 PM
Sorry to hear your speeds have dropped.
Have you tried running through our troubleshooter?
http://faults.plus.net
Message 2 of 6
(661 Views)
20-03-2015 8:35 PM
Yes, but thought maybe it was something simple
Message 3 of 6
(661 Views)
23-03-2015 2:58 PM
I've just had a look and the sync has gone back to over 1500, giving you a profile of 1250 now. Let us know if you have any issues and we'll take a look.
Message 4 of 6
(661 Views)
27-03-2015 8:21 AM
A few days later and all is not well low sync and speed
Home
Services
Settings
Site Map
System Info
Broadband
LAN
Firewall
Logs
Diagnostics
Link Test
Link Monitor
DSL
IP Utilities
NAT
Syslog
Resets
Physical Line 1
General Information
Downstream Atten. at 300kHz: 69.1 dB
Uncancelled Echo: -13.4 dB Ok
VCXO Frequency Offset: -22.1 ppm Ok
Downstream Impulse Noise Protection: 0.65
Framing Mode ATM
Training History
Downstream Upstream
2015/03/26 16:54:33 GMT 1 1632 1632 856 856 9.0 5.0 67.3 16.9 19926 338592 0.57 4.00 448 704 14.0 14.0 31.5 11.9 561 1447 0.94 4.00 G.DMT Annex A Alcatel 241/104 ERR_LOS_LIMIT -16.7 -17.8 29.9
2015/03/27 08:18:44 GMT 1 1056 1072 1048 1048 9.2 12.0 68.0 15.7 617 10043 0.65 4.00 448 684 13.0 13.0 31.5 11.9 21 147 0.94 4.00 G.DMT Annex A Alcatel 240/104 N/A -13.4 -22.1 29.9
Bitloading
0000000456677777777777666544430000000046654454046767764554203566666666624656656656545544404444424423222002200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Notes
Home
Services
Settings
Site Map
System Info
Broadband
LAN
Firewall
Logs
Diagnostics
Link Test
Link Monitor
DSL
IP Utilities
NAT
Syslog
Resets
Physical Line 1
General Information
Framing Mode ATM
Training History
Downstream Upstream
Bitloading
Notes
Message 5 of 6
(661 Views)
27-03-2015 6:28 PM
Message 6 of 6
(661 Views)
