Poor service since line speed increase
- Re: Poor service since line speed increase
23-10-2018 8:43 PM
First of all we are connected directly to the exchange here and previously we were told the max line rate was going to be around 12Mb/s which is about what we had. Connection was very stable and streaming TV perfect at 1080p.
Then around two weeks ago our connection went down for two hours and when it came up it was connecting at 21Mb/s and 1Mb/s up.
Everything seemed OK but over the last few days streaming TV in the evening is impossible and eventually slows down to what looks like 320x240 heavily compressed. My wife assures me that daytime streaming is OK.
24-10-2018 10:48 AM
Sorry to hear you've been having issues with your download speeds.
I've tested your line and that's not showing any issues with the connection looking stable and the speeds are what we'd expect for your line.
When you next have issues can you carry out a speedtest here over a wired connection? Once the initial result is completed please click Further Diagnostics. Please type in your phone number and click run diagnostic test. This will run a test and send the results to the server for investigation
24-10-2018 1:17 PM
Is it possible to check for a Hot SVLAN issue @MatthewWheeler. Recent service switchover / upgrade by OR may have created a number of hospots?
24-10-2018 2:56 PM
@MauriceC Yes, I've just performed a full KBD test and that has a category for "VLAN analysis" nothing is being flagged as an issue to us.
24-10-2018 10:26 PM
Things seem OK tonight. I will do the tests and report if it slows again.
Thanks,
Rich.
25-10-2018 11:12 AM - edited 25-10-2018 11:13 AM
Thanks for letting us know, @skuzzbag.
Please do, we would be more than happy to take an other look should it be required.
All the best,
MoR
*edit - correction of a spelling mistake.
29-10-2018 8:41 PM
The speed has dropped quite considerably tonight here are the test results from BTW
1. Best Effort Test: -provides background information.
Download Speed | |
2.29 Mbps |
0 Mbps | 21 Mbps Max Achievable Speed |
Download speedachieved during the test was - 2.29 Mbps For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps. IP Profile for your line is - 19.25 Mbps |
Upload Speed | |
0.26 Mbps |
0 Mbps | 0.83 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 0.26Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
This test was not conclusive.
please close the window using 'Exit' button and contact your ISP for further assistance with these results.
30-10-2018 11:53 AM
Sorry to hear the speeds have dropped again.
At this stage I'd recommend raising a fault here so we can investigate this further.
Let us know once you've done this and we'll get this picked up
30-10-2018 7:45 PM
Hi, I've raised a fault just now. Speed test was 8.2Mbps this evening.
31-10-2018 1:34 PM
