Poor quality router with Plusnet Fibre broadband
- Poor quality router with Plusnet Fibre broadband
28-08-2013 7:15 PM
I have a TG 582n for use with fibre broadband but the wireless signal is dire.
I have tried different channels, etc but even being a few meters away the wireless connection does not get anywhere near the speed of using a wired connection.
Does Plusnet have an alternative router type they could supply in replacement for this one ?
Message 1 of 2
(608 Views)
1 REPLY 1
Re: Poor quality router with Plusnet Fibre broadband
29-08-2013 9:38 AM
The TG582n is the only router we supply, have you been through all of the channels? It may be worth using inSSIDer to see what channel is best to use.
Have you tried to move the router from it current position to this if this helps?
Message 2 of 2
(305 Views)
