Poor latency at peak times
- Re: Poor latency at peak times
- « Previous
- 1
- 2
- Next »
02-12-2018 1:52 PM
Sorry to hear that.
It's normal for you to see higher latency when the connection is in use.
However if your speeds are poor too then maybe this is related. Do you experience the same issues across multiple devices?
If you can also provide us with a full traceroute (as opposed to certain hops), we can look into this further.
02-12-2018 4:50 PM
I don't believe the high latency is due solely to the internet usage on our line. As mentioned, I will setup port mirroring and wireshark to measure our internet usage, to compare against latency.
BTW, I found this article interesting and presumably relevant:
Can you tell me what the contention ratio is for our line?
Yes, we see issues across multiple devices - PCs, xbox, TV.
As mentioned, the full traceroute output was attached to the post on Thursday. Please shout if you're not able to access that attachment.
02-12-2018 6:32 PM
I only mentioned usage and the 2704n bufferbloat issue because I had assumed that you were on ADSL due to this thread being in Broadband rather than Fibre Broadband.
Unfortunately that ISPReview article is based on a fundamentally flawed analysis of the data. The data was originally from ThinkBroadband who measure congestion based on the difference between their single-threaded and multi-threaded speedtests. It makes little sense to compare the off-peak and peak average speeds the way ISPReview did, because the differences will be due to people with different line speeds testing at different times, nothing to do with congestion. If a higher proportion of people with faster lines did speedtests at peak times, then the peak average speed would be higher.
Broadband lines don't really have any notion of a contention ratio, in the sense that they aren't sold with a fixed specified contention ratio.
03-12-2018 9:19 AM - edited 03-12-2018 9:21 AM
Hi @patrickf,
I'm very sorry for any inconvenience that this issue is causing you.
I've tested your line and the test has now picked up an external line fault:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Fail | ||||
Test Outcome Code | GTC_FTTC_SERVICE_1625 | ||||
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report | ||||
Main Fault Location | CE | ||||
Sync Status | In Sync | ||||
Downstream Speed | 40.0 Mbps | ||||
Upstream Speed | 9.5 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | Y | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 434.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2018-11-20T09:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.4 Mbps | 9.9 Mbps | 9.8 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 898.2 Sec |
Retrains | 0.0 | 5.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-12-03T08:48:15Z | 2018-12-03T09:03:15Z |
Ingress Code Violation | 3 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I've raised this to our suppliers for further investigation and they have advised that their estimated response time is by midnight on the 5th of December. As it's an external fault, this is only an estimate and if they're able to investigate sooner than this they will. Our faults team will be in touch once we've received an update from our suppliers on this.
- « Previous
- 1
- 2
- Next »
