Poor fibre performance
ForestGrump
Hi, had Plusnet fibre installed a week ago.
Thought I would give it time to 'settle' before I contacted you but I am getting quite poor results.
Both me and my son play on Xbox live and at times it can be very 'jumpy'.
Also streaming on Sky go can be a bit dodgy by losing picture quality and sometimes it is like watching a 'stop go' movie.
I have done various Speed tests in the last week and it ranges from 6Mbps to 36Mbps down speeds but on all tests the speed graph seems very erratic, is this normal?
I am on the unlimited package and speeds should be up to 76Mbps.
Wayne
Fixes: 62
Re: Poor fibre performance
are all those tests and connections wireless
ForestGrump
Hi Oldjim, yes they are all wireless. Just did a wired test and it is around 50Mbps but more importantly the speed graph seems a lot more stable. Could it be a router issue or is it just a problem with wireless?
Hi Wayne,
It certainly seems to be a wireless issues that you're experiencing, I'd suggest trying to change your channel of your router, use this <a href="http://www.plus.net/support/broadband/wireless_broadband/wireless_signal.shtml">guide</a>, it may also be worth trying <a href="http://www.metageek.net/products/inssider">inSSIDer</a> to determine which channel is best to use.
Let us know how you get on.
Chris
