Poor connection speeds... again
andy499
Hi @plusnet
The problem of poor connection speeds and lag has come back for the 3rd time in less than a year.
I am currently not getting more than 29mbps wired or wifi. This is below guaranteed minimum. I expect a minimum of 40mbps as previously discussed.
Additionally, you have put prices up - and my service has again declined. I am getting very tired of having to do this.
6 REPLIES 6
Fixes: 382
Re: Poor connection speeds... again
@andy499 A bit more detail would help to resolve this:-
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
adamwalker
Fixes: 223
Hi there andy499, I'm really sorry that speeds are a problem again for you. I've just been running some diagnostic tests and they didn't show signs of any issues at all. Can you try following the checks outlined here next please? https://www.plus.net/help/broadband/connection-troubleshooting/ Let us know how you get on.
 Adam Walker
andy499
At the moment I’m getting a max of 22mbps, wired or wifi . Internet has been off for a week as I’ve been on holiday, it’s still no different. I’m tired of this happening all the time.
adamwalker
Fixes: 223
Hi @andy499, I hope you enjoyed your holiday and I'm really sorry that's still an issue. I've just been running some line tests which aren't flagging up any issues, have you been able to go through the checks I linked you to in my last reply a couple of weeks ago?
 Adam Walker
andy499
Yes all basic troubleshooting has been done already. I don’t post here until that is done. I don’t have a home phone though. Not had one since 2010. Do people still use these?
Fixes: 244
Yes they do - they are an essential diagnostic tool, even if you do not make phone calls.
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.  From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link.  NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
That is fundamentally where to start.  Either borrow a handset of pick up one from Argos for around £8.
The can you please post the router stats - they provide more information about what is really happening that data speed tests.
