Poor VoIP quality
- Poor VoIP quality
Poor VoIP quality
02-05-2013 9:27 AM
I have a stable connection from Plus.Net; a generally get about 18.5Mbps down/1Mbps up on speed tests. However, over the last week I've had great audio problems over Microsoft Lync. I'm not sure this is related to my ADSL connection, traffic prioritisation by Plus.Net, or of course something within my company's Lync network. The voice issues have primarily been upstream -- people having trouble with 'hearing' me, vs. me having issues hearing them (although both occasionally).
I do notice a large number of error seconds and HEC errors in the router status page. Is this something to be concerned with?
DSL Connection
Link Information
Uptime: 9 days, 1:44:18
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.227 / 22.226
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,32
Output Power (Up/Down) [dBm]: 11,9 / 0,0
Line Attenuation (Up/Down) [dB]: 9,4 / 21,0
SN Margin (Up/Down) [dB]: 5,4 / 3,0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 15.161 / 5
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 355 / 50.718
HEC Errors (Up/Down): 1.429 / 393.767
DSL Connection
Link Information
Message 1 of 8
(1,161 Views)
7 REPLIES 7
Re: Poor VoIP quality
02-05-2013 9:41 AM
I didn't think Plusnet did much traffic prioritisation with upstream data because there wouldn't be any point, as the data has already passed through the bottleneck of your ADSL line by the time it reaches Plusnet. Any prioritisation of upstream traffic would have to be done by your router.
However, you're not the only person reporting issues with Microsoft Lync 2013: http://community.plus.net/forum/index.php/topic,100343.16.html
Message 2 of 8
(713 Views)
02-05-2013 3:13 PM
That's a LOT of upload data - not often we see more upload being used than download. By the look of those stats something (not sure if it is Lync, though I guess it could be depending on what you're doing) is saturating your upload there which will be why the chat is stuttering and lagging.
Not sure what you had running on your PC at the time but that would definitely be worth looking at.
Message 3 of 8
(713 Views)
02-05-2013 4:43 PM
Do use torrents or any other P2P?
Message 4 of 8
(713 Views)
02-05-2013 7:51 PM
Quote from: Matt That's a LOT of upload data - not often we see more upload being used than download. By the look of those stats something (not sure if it is Lync, though I guess it could be depending on what you're doing) is saturating your upload there which will be why the chat is stuttering and lagging.
Where are you seeing the upload data values? The 'DSL Connection' page always shows fairly random data.
Comparatively on the 'Internet Services' page, I see this data for up/download:
Connection Information
Data Transferred (Sent/Received) [GB/GB]: 2,00 / 46,08
Message 5 of 8
(713 Views)
03-05-2013 11:10 AM
I was basing it on the same line from the stats in your previous post, presumably taken from when you were having the issue:
Quote from: jbnm Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,32
Message 6 of 8
(713 Views)
03-05-2013 11:35 AM
Now I'm confused. If I take the stats right now from the two pages on the router I get different values for data transferred:
Internet DSL Connection:
Data Transferred (Sent/Received) [GB/MB]: 1,99 / 838,74
Internet PPP Connection:
Data Transferred (Sent/Received) [GB/GB]: 2,11 / 50,20
Both show about 2Gb upstream, but one shows 838Mb downstream and the other shows 50Gb downstream. The second seems, total data wise, to be about right given the uptime of the router and the usage stats shown in the Member Centre.
So I'm assuming the DSL Connection data is wrong, at least on the downstream. As I observed in my last post, this value is seemingly random.
Message 7 of 8
(713 Views)
04-05-2013 10:08 AM
@jbnm I have been on at PN for a very long time, the company I work for is actually a Microsoft Partner for Lync. There are many variables.
How long have you been using Lync? Have you always had these problems or have they just started? Are you using the Lync 2010 or 2013 client? Is your company using the 2010 or 2013 Lync Server?
Tell me about your Lync call. Did you just use audio? How many people were in that Lync call? DId they all use a Lync client to call in or did some people dial in from a landline too? Were all the people on the Lync call from your company and so using the native Lync clients on their devices? Or they were using the downloadable Lync client which they install because they are not in your company?
Were you using any screen sharing or whiteboard functions? Were you videoconferencing too with Webcams? If you were screen sharing, did you find the audio would break up when the screen sharing needed to change a larger part of the display for example, somebody changed page during a powerpoint presentation?
If you want to make progress, you need to learn a little to use Wireshark and capture the packets of an ongoing Lync call.
3Mb FTTC
3Mb FTTC
Message 8 of 8
(713 Views)
