Poor Speeds And Dropouts
DerekW
Re: Poor Speeds And Dropouts
@Anonymous
With of without QoS turned on? or both?
"No one has ever become poor by giving" - Anne Frank
DerekW
@Dan_the_Van
I might give it try a try in the morning and see how I get on
@DerekW   -  Might as well have both, so we know the limits of the bad and too good !
Then we'll be able to tune the numbers as best compromise between speed and latency.
At this stage all you need to do is eliminate the blue spikes, because they have been known to cause line drops.
So a bufferbloat score of say 'C' would be enough for you to have one less potential cause for instability.
DerekW
@Anonymous
Here you go
The speed given on the A+ one is below my guaranteed minimum - without the QoS turned on I regularly hit speeds of 69 up and 18 down.
Ok, that's a good start.
Have you adjusted anything in the "Advanced" settings part of the "QoS" page ?
Can you do a screenshot of the "QoS" page with the "Advanced" section showing
DerekW
@Anonymous
Sorry, the forum never told me you had posted
I'm a bit baffled by the speeds in your "A+" result, because on my router's QoS, the bufferbloat up and down speed results are the same as the limiter bandwidth numbers that I've entered,  therefore I was expecting your test result to be 65/15.
When I saw your actual result was about 80% of the bandwidth numbers, I wondered whether your Advanced High Priority slider was set to 80%,  but it doesn't appear to be that.
Anyway the idea here is to increase your up and download bandwidth numbers in small steps, then do a bufferbloat test, until you get back to a decent speed, without the bufferbloat grade being any worse than say a "B" or "C".
So changing one thing at a time.  What bufferbloat do you get with Upload Bandwidth set to 18
DerekW
@Anonymous
With QoS set at 18/65 I get the following
and with Download bandwidth set to 70 ?
I've got a spreadsheet tracking this now !  LOL
DerekW
@Anonymous
With QoS set at 18/70 I get the following
DerekW
Did you mean  18/65  or   18/70  ?
You're messing up my spreadsheet !  😃
DerekW
 Errrmm... *cough* copy & paste error
Adjusted...
18/70
It's interesting that the speed result only changes by about 80% of the step size of the bandwidth change.
OK next, can you do a   19/74   and a   20/80
to see what that tells us !
