Poor Internet Speed on Laptop but Good on Mobile Phone
FIXED- Subscribe to RSS Feed
- Poor Internet Speed on Laptop but Good on Mobile P...
4 weeks ago
- last edited
4 weeks ago
by
Have checked dns settings have done flush have changed settings to google dns but no good.Get 200/250 on mobile but only 50 on laptop.This happened very quickly on day all ok next day down to 50.
have tried all sugestions on internet.
Have checked Wi-fi adaptor and it comes up as working ok.
Any help would be appprciated
Moderators Note: All caps title removed as per Forum rules
Fixed! Go to the fix.
Re: POOR INTERNET SPEED ON LAPTOP BUT GOOD ON MOBILE PHONE
4 weeks ago
Have you tried an Ethernet connection to the laptop? The fact that your phone still gets good speeds points very strongly to a fault with that machine.
4 weeks ago
@daviddoc sounds like the laptop is sometimes connecting to the 2.4ghz band rather than the 5ghz one.
Make sure that the wifi adapter is set to 'Prefer 5ghz'
4 weeks ago - last edited 4 weeks ago
Assuming that you have a Plusnet Hub Two router, it has two WiFi bands - 2.4GHz and 5GHz.
5GHz has a shorter range but provides better bandwidth and therefore much faster speeds.
2.4GHz has longer range, but slower speeds (and 50Mb isn't unusual).
Your laptop is probably switching between those bands depending on the WiFi signal strength, resulting in different speeds.
Check your laptop's WiFi connection status to see which band you are connected to.
Find in your laptop's WiFi adaptor settings, whether you can disable automatic band selection, and always choose 5GHz ?.
Alternatively, you could switch OFF the 2.4GHz band in the Plusnet Hub Two, so EVERYTHING always connects at 5GHz.
Watch this video - YouTube : Changing your Hub Two wireless settings
then at time = 1:20 you should see the web page shown below,
then toggle the 2.4GHz wireless to OFF, then hit the [Save] button.
4 weeks ago
its even worse when plugged into router.
4 weeks ago
Which router do you have? What technology are you on FTTC or FTTP?
4 weeks ago
full fibre and hub2
4 weeks ago
@outcast No need for sarcasm, I'm not in the mood for dealing with it today. As a point of interest, I assumed the OP was on FTTP, given those reported speeds, but as they said later 'it's even worse when plugged into router' - message #5 - we may be going down a blind alley - as we all know, n Ethernet connection should give the 'paid for' speeds, unless there is something wrong with the users kit/set up.
@daviddoc wrote:
full fibre and hub2
OK - try turning off the 204Ghz band as advised earlier, and see what happens.
4 weeks ago
HI HAVE NOW TURNED OFF 2.4GHz
all working ok now
thanks everyone for youe help
4 weeks ago
"Get 200/250 on mobile but only 50 on laptop."
To clarify, when you are testing these speeds, are the mobile and laptop next to each other in the same part of your home, relative to the router?
4 weeks ago
yes they are both reading 275 i am on a 300 package
