Poor Fibre speed
mkdavy
Poor Fibre speed
We are having difficulty with our fibre speeds, especially over WiFi. The connection will drop if more than one device is trying to stream video content. I did a speed test overnight (over WiFi as I did not have a device to connect to the ethernet port). The minimum speed (when it didn't drop out) was 1.37Mbps, the maximum was 25.85Mbps. this is far below my guaranteed minimum speed of 58.3Mbps.
The house is a 1980's house with thin plasterboard and cardboard internal walls. I was some distance away from the Router but not at the supposed edge of the range as the house is not overly large.
Could someone please investigate to see if there is a problem on the line? We have had openreach and virgin working nearby recently due to a new housing estate being built.
5 REPLIES 5
Fixes: 387
Re: Poor Fibre speed
@mkdavy
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
mkdavy
Hi John,
I did the quiet line test which was fine. I managed to do a sped test closer to the router and the speeds were much better at around 72Mbps.
The speed in the original location is still really poor. It’s probably between 5m and 6m away from the router on the floor above. The equivalent position in the same floor gets around 34Mbps, so now I am assuming there must be some interference/range issues. We we probably have to look at getting a mesh system
Fixes: 387
What hardware do you have (computers/phones/tablets)? That second set of speed tests looks better. Just as a thought, are you aware of what is between the walls - I'm beginning to suspect foil insulation?
mkdavy
Between the router and the room in question. There will be one solid block wall that is a small portion. The rest of the internal walls are plasterboard with a honeycomb cardboard centre. There is no foil insulation or any insulation in between the joists in the floor/ceiling. The the room is one floor up. We mainly use two 5th generation iPads, an iPhone 11, an iPhone 13 Pro and a Samsung smart tv in this room though not usually all at the same time. The speed test was done on the iPhone 11 when nothing else was on.
Fixes: 387
Thanks for the good explanation re the construction. If all the hardware is dual-band (the Apple kit is), my next thought is, is it trying to hold on to the 5Ghz when it should ideally be using the 2.4?
