Poor Connection Performance.
- Poor Connection Performance.
25-10-2007 12:33 AM
Hello,
Having been browsing through the forum I realised my download speed (2250kbps max) is somewhat on the low side.
I have run several BT speed tests, at various times of day and over several days.
The results are as follows :-
IP Profile - 7150kbps
Connection rate - 8128 down stream, 832 upstream.
Last two throughput results - 1766kbps, 1788kbps.
The highest throughput I have ever achieved on the speed test is around 2200kbps.
Could you please look into this and check if there is a problem, as the speeds seem too low for the IP profile and connection rate.
Thanks.
Thanks.
Message 1 of 3
(1,055 Views)
2 REPLIES 2
Re: Poor Connection Performance.
25-10-2007 9:57 AM
As Peter suspected, we weren't profiling your line correctly at our end.
I've amended your profile now and if you reboot your connection, you should start to see imoproved speeds.
Message 2 of 3
(290 Views)
25-10-2007 12:32 PM
Thanks James for the quick resolution.
I have just run another speed test and achieved 6140kbps.
Message 3 of 3
(290 Views)
