Policy on Tor relays
Flint
Does Plusnet have a policy on their users running a Tor relay or exit node?
(Assuming that Tor is configured with sensible bandwidth throttles in place)
http://www.torproject.org/
Ta!
Re: Policy on Tor relays
I would have assumed that running a Tor exit node on your system would be fine - although any traffic will be attributed to you (and counted twice - once for incoming, and once for outgoing)
B.
acarneiro
Any possibility of one of the PN guys to comment on this one? I would consider having a 10MBit Tor exit node on my connection when (and if!) I actually get my FTTC connection... But I really don't want to overburden PlusNet nor be sent to prison for traffic attributed to me that might be less..... palatable.
Fixes: 10
You will be responsible for all the traffic - I don't think this is in any way a wise move!
If you are contacted by the authorities you would not be able to use the defence that it was someone else unless you could say who it was - you'd have no way of knowing that.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 10
You should also take a look at the Plusnet terms and conditions: http://www.plus.net/info2/legal/index.html
E.g.
15. You may only use the service for your own personal use and enjoyment. You must always follow our acceptable use policies in the way that you use your chosen services which can be found on http://www.plus.net/info2/legal/aup.html.
acarneiro
Hmmm.... Well, I guess if I had the time, money and inclination I could contest any legal proceedings. I am led to believe it has been done successfully in the past.
As I have none of those, though, I might just relay rather than exit instead.
As for the enjoyment, that's a bit of a tricky one, isn't it? I enjoy running a Tor relay Wink
Thanks for the replies, guys Smiley
