Plusnet support router remote management?
- Plusnet support router remote management?
30-12-2008 11:31 AM
Can anyone tell me if Plusnet supports router remote management (Im on BB your way pro)?
In other words can I browse to "http://mypublicIP/port that i chose" or is it blocked?
Many thanks
Many thanks
Message 1 of 3
(1,481 Views)
2 REPLIES 2
Re: Plusnet support router remote management?
30-12-2008 11:38 AM
We don't block any any ports on our network (we used to block port 135 for everyone years ago, but is no longer the case). Assuming your firewall settings are correct and you have enabled the remote management feature on the router, this should work just fine.
Ian
Ian
Message 2 of 3
(756 Views)
30-12-2008 12:57 PM
Additionally, ensure you are using the correct URI fomat of http://mypublicip:port/ (note the colon)
Message 3 of 3
(756 Views)
