Plusnet's own DNS servers
JayG
Fixes: 6
Re: Plusnet's own DNS servers
I think you need to log in as 'expert_user' followed by the router password:
http://192.168.1.254/expert_user.html
Cagney1994
@JayG - I've logged in via the 'expert user' option and it takes me to an 'Enable Dynamic DNS Service' option.
This is within the 2704n router interface:
Now presumably where it says 'Host', that's where you'd put the DNS server information?
Browni
Aspiring Hero
Fixes: 61
What's under the DNS tab?
JayG
Fixes: 6
Yes, to change the DNS servers you need to click the DNS tab.
Cagney1994
@JayG - Thanks.
@Browni - This is what's under the 'DNS' tab:
And the drop-down menu looks like this:
Both Open DNS and Manual DNS are 208.67.222.222
Browni
Aspiring Hero
Fixes: 61
I would have expected selecting manual would allow manual entry of the servers you want?
Cagney1994
@Browni - Oops! - you're right. I didn't know you could actually edit the box after selecting 'Manual'  Shocked
Silverhoop
Did you ever get this resolved?
I have not been able to access 1 site - Betfred
I called Plusnet and they have changed my IP address, I have re-booted my router (Leaving it off for more than 3 hours)
I have flushed my DNS, changed the address re-booted everything but sadly all to no avail
Does anyone have any further ideas on why I can't reach Betfred? I can reach all other gambling sires
Fixes: 237
Hi @Silverhoop,
A warm welcome to the forums.  I doubt that your problem has anything to do with this topic, but is very likely to have a lot to do with this one - https://community.plus.net/t5/Plusnet-Feedback/IP-addresses-not-UK-Can-customers-please-report-any-p...
majorzombie
Hello guys. I know this thread is old, but it is still relevant.
Anyone here that can help me change my DNS primary and secondary?
There is no option for me to change them, i want to use cloudflare 1111 1001.
Ask me what i need to provide to help you help me, and tell me where i can find that info too. Treat me like a noob with above average common sense.
Thank you, i will subscribe to the thread also.
SpendLessTime
Fixes: 86
@majorzombie
if you have a Plusnet router which doesn't allow for you to change DNS, you would need to change it on your computers, phone etc.
Best just to Google "change DNS" and add the make of phone/tablet/operating system and follow that advice.
majorzombie
Yes it seems i do.
Is there a plusnet router that allows it, would i be better off with one of those?
It is mainly for a strong gaming connection, i will try the console settings also. Thank you.
SpendLessTime
Fixes: 86
If you wish to buy your own device, a good list and discussion is available at http://forum.kitz.co.uk/index.php/topic,14436.0.html (VDSL/FTTC all-in-1 units)
This list is updated as new models become available so don't be fooled by the opening date.
Just remembered that this thread is in the ADSL broadband section but most of the devices mentioned at Kitz's forum are backward compatible with ADSL.
Plusnet routers are locked done to make their life(support) easier. Not to give us flexibility.
