Plusnet router crashes macbook
- Plusnet router crashes macbook
19-06-2015 12:23 AM
I have swapped back to the BT router because the service is still active, restarted the macbook and it works fine.
I have tried to connect to the Plusnet router several times but it freezes every time. I have also tried leaving the router off, starting the macbook, then switching on the router. Up until the point where the macbook connects to the network it is fine, but freezes as soon as it does.
I have an ADSL faceplate but I've also tried with the micro filter, which changes nothing.
iOS v 10.6.8. done software updates and still no joy.
Please advise.
Re: Plusnet router crashes macbook
19-06-2015 12:30 AM
19-06-2015 7:05 AM
19-06-2015 1:13 PM
Disabling IPv6 has worked though, so thanks for that :).
19-06-2015 1:32 PM
19-06-2015 1:59 PM
12-08-2015 9:46 AM
I set up my new router last night and everything was working fine with it when using my iPhone 4 and all the wireless let me connect up my Sonos Playbar.
When I came to use my Macbook Pro and also my girlfriend using her Macbook we both had the same issue, we got the spinning wheel of death and we couldn't do anything else beyond this point. We couldn't even force quit Safari. All we could do was press the power button to turn off the laptops.
When our wireless Airport is turned off we can use the machines just fine but there is something to do with the wireless router that is causing our laptops to stall. Both our iPhones work as normal.
In the instruction manual I read something to do with Wireless N and Wireless G technology and I'm guessing this might have something to do with why our older laptops are not working. I'm certainly not prepared to by a new Macbook Pro to be able to use the internet.
I spent hours trying to work out what the problem was.
I'm going to try and turn off the Airport and log into the Sagecom router to see if there is anything I can change to sort the problem out.
I'm not sure whether updating to an OS X operating such as Snow Leopard might update our wireless setting to allow us to use the router.
Any help would be greatly appreciated.
09-01-2017 9:30 AM
Tried everything. PC, iPad and iPhones all work perfectly but my MacBook Pro just crashes when the Plusnet router is on.
Wasted hours trying to figure it out while it was crashing and never thought to investigate the router.
I don't want to have to use a different router now that everything is installed in my office. Any workaround?
09-01-2017 9:32 AM
Are there any disadvantages as is this turning off a feature?
15-02-2018 9:42 PM
21-02-2018 9:55 AM
21-02-2018 10:33 AM
Is the MAC's inability to work with IPv6 configured restricted to WiFi connectivity?
21-02-2018 10:35 AM
21-02-2018 12:10 PM
@adamwalker, it might also be worth pointing out that Rebeccay 's posting is from over 2 1/2 years ago!
16-03-2018 6:49 PM
