Plusnet profile vs BT Profile
- Plusnet profile vs BT Profile
28-03-2011 11:16 AM
I note my Plusnet profile is only 2500 so presume this is the cause - I understood the Plusnet profile tracks the BT profile twice daily?
Could someone have a look at this please.
Ticket 41133163 raised on Saturday (no response!) also refers
Regards
Re: Plusnet profile vs BT Profile
28-03-2011 11:22 AM
If you do then the Plusnet profile is indeed the problem
28-03-2011 11:31 AM
Here is latest BT speed test:
Download speed achieved during the test was - 2109 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8257 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 19.68:27.74:52.59 (SBE:NBE:PBE)
Regards
28-03-2011 11:36 AM
Mike
28-03-2011 1:40 PM
Quote from: Mikewalsh Your DSL Connection Rate :8257 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
Whatever you want to call it, your Connection Rate or Sync speed is 8257kbps. The IP Profile that goes with that is 7150kbps, and the BT Performance Tester result correctly shows that value.
You mentioned the Current line speed shown in the Member Centre is 2500kbps; it should be 7150kbps. This might mean the value is stuck and needs a manual update, or there could be an inconsistency in the BT systems. Either way Plusnet need to check it out and fix the problem.
28-03-2011 4:37 PM
Pretty Please
29-03-2011 9:04 AM
I'm afraid the BT profile is showing at 2500 on one of their reporting tools, which is I suspect why the agent replied as he did. As the speed test is reporting differently though I suspect there's a mismatch there. I'll do some tests shortly and post back.
29-03-2011 11:36 AM
29-03-2011 1:18 PM
I did have a rogue connection on the 23rd but reconnected and recovered as soon as I noticed it. BT intitally dropped to 2500 but recovered 24hours later and since then their profile has been 7150. The speedtest on my first post (28th) is typical. I am at work so can't do another at the moment. There is also a similar speed test in my ticket.(on the 24th).
Regards
Mike
29-03-2011 1:37 PM
Further to my last I daren't do a speedtest during the peak period in the evening because my speed drops below 2000 (BT's acceptable speed range is 2000 to 7150) so it shows up an error. Not sure why Daniel saw my router as off-line as it is on 24/7.
Cheers
Mike
29-03-2011 2:43 PM
Still seeing the same issue on another test, so I've reset the SNR on the line - this should kick everything back into line again for you. Best bet would be for you to resync the router once a day around lunchtime, by actually disconnecting the ADSL from the router interface and then powering it off, then back on again (using the interface is important, if you don't the exchange may record the disconnection as a fault).
It should take effect within the next hour or so.
29-03-2011 2:57 PM
Will try and setup remote access on my TP-Link Router in which case will be able to do it from work.
Rgds
Mike
29-03-2011 5:26 PM
First reboot - things are much the same Plusnet Profile 2500. BT Profile 7150 - good connection
BT Test 29/03 1715
Download speed achieved during the test was - 2241 Kbps
Your DSL Connection Rate :8402 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
The throughput of Best Efforts (BE) classes achieved during the test is - 22.69:27.7:49.64 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
Router Stats
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 6.2 26.0
Attenuation (dB): 42.5 21.4
Output Power (dBm): 13.1 0.0
Attainable Rate (Kbps): 10188 1076
Rate (Kbps): 8402 444
MSGc (number of bytes in overhead channel message): 61 10
B (number of bytes in Mux Data Frame): 126 63
M (number of Mux Data Frames in FEC Data Frame): 1 1
T (Mux Data Frames over sync bytes): 2 1
R (number of check bytes in FEC Data Frame): 10 0
S (ratio of FEC over PMD Data Frame length): 0.4818 4.5310
L (number of bits in PMD Data Frame): 2275 113
D (interleaver depth): 64 1
Delay (msec): 7 1
Super Frames: 932 49427
Super Frame Errors: 0 0
RS Words: 124916 0
RS Correctable Errors: 33 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 0 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 17630962 545173
Data Cells: 267802 45745
Bit Errors: 0 0
Total ES: 0 0
Total SES: 0 0
Total UAS: 32 0
This has been the same all weekend until today?
I am about to change routers from the TP-Link back to the TG585 v7 to see if that makes any difference.
Rgds
Mike
29-03-2011 5:40 PM
I will leave things as they are till everything settles. But I am now seeing a more realistic download speed.
Cheers
Mike
