Plusnet please help!
- Plusnet please help!
- « Previous
- Next »
Re: Plusnet please help!
21-03-2011 3:18 PM
Hi xRainex,
It looks like we need to get an engineer visit booked to continue the fault investigation - if the issue is still apparent please reply to the ticket advising when you'd be available, unfortunately we can only book either a full morning (between 8 and 1) or a full afternoon (between 1 and 6) on weekdays. If you let us know when you'll be in we can arrange this and carry on the investigation for you.
Message 31 of 35
(254 Views)
21-03-2011 4:03 PM
Mode: ADSL2 PLUS
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 1152 kbps 448 kbps
SNR Margin (dB): 16.1 12.8
Attenuation (dB): 56.0 31.9
Output Power (dBm): 12.3 11.3
Super Frames: 21226371 21226362
RS Correctable Errors: 1810 0
RS Uncorrectable Errors: 2429 163
HEC Errors: 1445 0
Total Cells: 40480 58437
Data Cells: 41886386 19653701
Bit Errors: 0 0
Type: ANNEX_A
Status: Showtime
Downstream Upstream
HEC Errors: 1445 0
Bit Errors: 0 0
Message 32 of 35
(254 Views)
27-03-2011 2:26 PM
The BT engineer that came out to my house this week said my line should be syncing at 4.1mb but it still hasn't reached that, he said if it doesn't to get into touch with PN. He didn't find anything wrong with the line, all he did was change the old master socket to a new one with an ADSL face plate. Speeds have been a lot better now though, staying at around 2.2mb.
Mode: ADSL2 PLUS
Type: ANNEX_A
Status: Showtime
Downstream Upstream
Rate (Kbps): 3065 kbps 446 kbps
SNR Margin (dB): 7.3 10.0
Attenuation (dB): 56.0 32.1
Output Power (dBm): 18.3 11.3
Super Frames: 6241879 6241896
RS Correctable Errors: 55168 827
RS Uncorrectable Errors: 1864 49
HEC Errors: 1682 0
Total Cells: 323248 275631
Data Cells: 15886412 4378174
Bit Errors: 0 0
Mode: ADSL2 PLUS
Type: ANNEX_A
Status: Showtime
Downstream Upstream
HEC Errors: 1682 0
Bit Errors: 0 0
Message 33 of 35
(254 Views)
29-03-2011 11:54 AM
HI xRainex,
I'll take a look for you and see what I can find out.
Jojo
Jojo
Message 34 of 35
(254 Views)
29-03-2011 12:27 PM
HI xRainex,,
I've just been on to BT and had the banding removed, which means you'll sync higher, so we'll see how it goes from here.
Jojo
Jojo
Message 35 of 35
(254 Views)
- « Previous
- Next »
