Plusnet outage
- Plusnet outage
Re: Plusnet outage
30-08-2014 6:35 PM
What is the error message you get if it doesn't connect?
Re: Plusnet outage
30-08-2014 6:36 PM
Quote Sure it's not just a disconnection Tijara?
Hi Kelly. No, everything was solid green at this end, just no internet connection. Eventually I had to recycle my router to regain a connection. My connection just stopped working, all on it's own.
Re: Plusnet outage
30-08-2014 6:43 PM
Re: Plusnet outage
30-08-2014 6:46 PM
Re: Plusnet outage
30-08-2014 7:03 PM
Re: Plusnet outage
30-08-2014 7:37 PM
zarnywoop has done all that, it's in his first post on this thread IIRC.
Re: Plusnet outage
30-08-2014 7:53 PM
Re: Plusnet outage
30-08-2014 9:12 PM
I use a TP-Link TD-W8970 which has been working perfectly up until these network issues. I get the error message "ppp1 lcd down" in the logs. If need be I'll bite the bullet and phone support but if anyone has any advice it'd be much appreciated.
Re: Plusnet outage
30-08-2014 9:28 PM
I was disconnected yesterday for the afternoon and to get back on it took me logging into router and disconnecting. Then power off for at least half hour then powered on. It took a couple of reboots like this once the problem was solved at Plusnet. I didn't disconnect the fibre modem in all this. My connection appears to have been ok since. Hope that helps.
Re: Plusnet outage
30-08-2014 9:52 PM
Quote from: wildbill Are the problems really considered to be sorted now? My connection's still dropping every 20 minutes or so. I've been logging into my router and manually reconnecting which sometimes works but not every time. I've taken the advice on this thread to turn the router off for half an hour which hasn't fixed it unfortunately. I'm really not keen on spending an hour on hold to support but have raised a ticket which has received no response yet.
That doesn't sound related to the outage, more like a fault.
Ex-Broadband Service Manager
Re: Plusnet outage
30-08-2014 10:05 PM
That sounds about the right sort of thing to do with the router on Fibre. Wise not to touch the modem.
Re: Plusnet outage
30-08-2014 10:08 PM
Re: Plusnet outage
30-08-2014 10:10 PM
It seems like most of the remaining problems could be related to stale sessions not dying? Would that be right and why aren't they dying?
Re: Plusnet outage
30-08-2014 10:13 PM
Re: Plusnet outage
30-08-2014 10:18 PM
Quote from: Anotherone Justin7, Kelly said it was their end but there is evidence around the net that some other services were affected so I think it's all as clear as mud.
That's interesting, but must make it difficult to diagnose. Hope they can figure it out so it doesn't reoccur. Plusnet are usually transparent with things so hopefully they'll post here with their findings next week when their techs have had a chance to look into it properly.
