Plusnet outage
- Plusnet outage
Re: Plusnet outage
29-08-2014 8:51 PM
Not sure in the end how much downtime was Plusnet and what was down to me. I'd restored my config from a backup after my pfSense upgrade went badly wrong and had forgotten that I changed the Plusnet password in the intervening period.
No modem reset necessary.
Steve
Re: Plusnet outage
29-08-2014 9:07 PM
Re: Plusnet outage
29-08-2014 9:13 PM
Quote from: Oldjim For information Andrews and Arnold are not showing any problems so I suspect that it is a Plusnet problem rather that BTw
That doesn't always follow as AAISP might have their LNS's in a different connection connected to a different POP to Plusnet.
Re: Plusnet outage
29-08-2014 9:14 PM
Re: Plusnet outage
29-08-2014 9:16 PM
@Jim http://community.plus.net/forum/index.php/topic,131222.msg1144348.html#msg1144348 suggest don't merge either.
Re: Plusnet outage
29-08-2014 9:19 PM
212.159.6.9, 212.159.6.10, 212.159.13.49 & 212.159.13.50 are all behind a load balancer so it shouldn't really make too much difference. Ifyou are having trouble with one, then you may with the others, but then it could be your current routing causing the problem or anything else.
Re: Plusnet outage
29-08-2014 9:59 PM
I'm not sure if PN will explain exactly what the problem is/was - but if you look at the POSI (Point of Service Interconnect - the link between the 21CN network and PN's datacentres) graphs here http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml, you will see the outage only affected 20/21CN users connected via Colindale. This to me would indicate an issue with the interconnect, which supplied by BT Wholesale. But it's all a bit of a guess by me.
Re: Plusnet outage
29-08-2014 10:16 PM
Re: Plusnet outage
29-08-2014 10:30 PM
Re: Plusnet outage
29-08-2014 10:50 PM
Aug 29 16:22:51 rc_service: ntp 715:notify_rc restart_upnp WAN Connection: WAN was restored.
Re: Plusnet outage
29-08-2014 10:54 PM
Andy, If you look at the collated users online, something died not long after midday maybe nearer 1300. It looks as though things were going down fromthen on. Service Status was posted at 1338 and then a lot more went just before 1430 or thereabouts.
Re: Plusnet outage
30-08-2014 12:01 AM
Re: Plusnet outage
30-08-2014 6:03 AM
Re: Plusnet outage
30-08-2014 6:14 AM
Re: Plusnet outage
30-08-2014 8:16 AM
Quote from: Xreyuk ...........Can't give you exacts because the router locked up when it went down for some reason and had to be rebooted.
This can happen, others and myself have experienced this with a variety of modem/routers, it seems it just depends on the way things fail
See my suggested advice in replies #71 & #72 especially if on FTTC but also this if on ADSL more so if on 20CN, and on a longer line. On a short line you can get away with more without necessarily affecting the profile.
