Plusnet outage
- Plusnet outage
Re: Plusnet outage
29-08-2014 4:33 PM
Glad to know it's not me and I can grab a coffee knowing someone else is on the case!
Steve
Re: Plusnet outage
29-08-2014 4:34 PM
Re: Plusnet outage
29-08-2014 4:39 PM
Re: Plusnet outage
29-08-2014 4:39 PM
Re: Plusnet outage
29-08-2014 4:41 PM
Out of interest there are two FTTC connections at these premises and the other one, which is BT, has been rock solid.
Steve
Re: Plusnet outage
29-08-2014 4:44 PM
Re: Plusnet outage
29-08-2014 4:45 PM
Trouble is when something like this happens you have no idea WTF is going on unless you have an alternate means of accessing PlusNet
Re: Plusnet outage
29-08-2014 4:45 PM
Re: Plusnet outage
29-08-2014 4:50 PM
Re: Plusnet outage
29-08-2014 4:53 PM
As the failure looks to be in the BT network, a lot of users won't be even connected to any Radius servers so can't authenticate and will be getting an IP address 172.xxx.xxx.xxx until such time as BT re-route things or repair what's gone down.
Rebooting your modems or modem/routers at this time will likely upset you connection to Cab or exchange depending on whether you are on FTTC or ADSL, so it's a case of sit it out at the moment until things are re-routed.
Edit: getting myself in a twist here, you'd be unlikely to get the BT Wholesale page 194.74.65.98 in the event of a failure in BT's network. Reference removed above. You tend to get that if the failure is more associated with Plusnet.
Re: Plusnet outage
29-08-2014 4:54 PM
Quote from: stephenw10 Still seeing 172.16 address here in London.
Steve
That's because the problem is with Plusnet and not the BT network
Re: Plusnet outage
29-08-2014 4:56 PM
And it was 172.xxx I'd intended to mention above, now edited the typo also corrected part of my comment.
Re: Plusnet outage
29-08-2014 4:56 PM
Quote from: DerwentMailman Been out for about 2+ Hours. Finally came back on at about 1630 after much fruitless cronking around in the router plus swearing at the cat. I noticed that my speeds are a tad down on the rock solid figures of the last month. Gratifying to know it was not a problem at my end.
your speed should never be affected by messing with the PN technicolour router. It's only the BTO white Modem that will cause DLM to kick it. The PN router piggybacks onto it and just signs into the ISP - as all ISP's handle traffic this way
Re: Plusnet outage
29-08-2014 4:58 PM
Quote from: Anotherone This is because there looks to me like a failure in the BT Network somewhere that has caused customers that were connected to Gateway ptn-bng01 and Gateway pcl-bng02 to lose connection.
As the failure looks to be in the BT network, a lot of users won't be even connected to any Radius servers so can't authenticate and will be getting the BT Wholesale page (IP address 173.xxx.xxx.xxx) until such time as BT re-route things or repair what's gone down.
The problem was in PN. The IP address people are reporting is that of the radius server and they probably found tr69@plsudsl.net as the username. If it was a BT problem the guy a few posts back would have found his other line was the same.
Re: Plusnet outage
29-08-2014 5:01 PM
