Plusnet outage
- Plusnet outage
Re: Plusnet outage
30-08-2014 10:18 PM
Quote from: Anotherone Justin7, Kelly said it was their end but there is evidence around the net that some other services were affected so I think it's all as clear as mud.
What have you seen?
Ex-Broadband Service Manager
Re: Plusnet outage
30-08-2014 10:26 PM
Re: Plusnet outage
30-08-2014 10:31 PM
Edit: It looks like the EE/T-Mobile datacentre is in West London (Equinix) - so just a coincidence they had issues at the same time as PN.
Re: Plusnet outage
31-08-2014 9:37 AM
Re: Plusnet outage
31-08-2014 9:49 AM
Re: Plusnet outage
31-08-2014 10:12 AM
Re: Plusnet outage
31-08-2014 10:44 AM
Re: Plusnet outage
31-08-2014 11:02 AM
As for some of the others - I think (might be completely wrong) it's because the BRAS/MSE hasn't dropped the L2TP tunnel despite the PPP disconnect, so it's not recognising new PPP attempts with the existing tunnel. There should be a timeout (30 mins? 60 mins?) where the tunnel will drop if no new PPP attempts are made.
Re: Plusnet outage
31-08-2014 11:06 AM
Quote from: Anotherone It would be nice if someone from Plusnet could give us some sort of decent understanding of these stale sessions as mentioned here
Once I know enough not to mislead, I will.
Re: Plusnet outage
31-08-2014 11:33 AM
Quote from: AndyH I think wildbill has a line fault - assuming he's on ADSL, his line stats should be useful.
Are line stats I'm able to get myself? I'm googling how to get them for my TD-W8968 router but haven't found an answer yet. I'm recognising I'm probably going to have to dig out the plusnet router in order to go through the full fault diagnostic process in any case, I just don't have time right now
Edit: Unless these are the stats needed? https://dl.dropboxusercontent.com/u/32446521/TD%20W8968.png
Re: Plusnet outage
31-08-2014 11:41 AM
Re: Plusnet outage
31-08-2014 11:52 AM
Call PlusNet, nice guy on support...check router and reboot as diagnostics are saying I am trying to reconnect using invalid ID and password.
According to Support at the time, there were 2 issues Friday, the first was said to be a wider network problem and the second, a knock on, with PN which prevented users like me authenticating.
At least I had the option of switching back to Virgin - which was kind of ironic as i am switching due to ongoing stability and utilization issues in my area. Now, though, back to monitoring speeds and consistency with PN.
Let's see how it goes.....
Re: Plusnet outage
31-08-2014 2:07 PM
I have a 3-4mb connection according to plusnet but i only get a 200kbp/s download speed when i download something from steam or origin. Is this normal or has it been capped?
Re: Plusnet outage
31-08-2014 2:14 PM
Which is a step in the right direction (assuming this figure is correct)
Re: Plusnet outage
31-08-2014 2:38 PM
Also took a bit to convince him that the problem I was having wasn't same problem as eveyone else.
