Plusnet needs to change there trusted broadband speed test site!
- Plusnet needs to change there trusted broadband sp...
14-01-2019 12:18 AM
This is a long read but i need to state this as plusnet is breaching the contract i have with them!
Ive been with plusnet for a while now and to be honest i have not had a good time with them, when i first joined i was guaranteed 6mbs minimum download speed but i have never received that, anyway first time i called them i got put through to the tech part of plusnet to see whats going on with my speeds, the guy i was speaking with told me to go to speedtest.btwholesaleso i can test my speeds and he can monitor them, before the call to plusnet i tested my speed using 7 different speed test sites (all trusted ones) including
Re: Plusnet needs to change there trusted broadband speed test site!
14-01-2019 8:15 AM
The assured speed is line synch speed not data speed. What do the router stats report?
Is for the down load speed reported are you certain that the units are bits and not bytes?
The Think Broadband site offers a good reference speed test,
14-01-2019 2:03 PM
Hi @Jordan2703, firstly, I'm really sorry that you have been experiencing issues with the service.
We ask customers to use the BT speedtester as this has the ability to upload the results so we can view them and use this when raising a fault, though it is not vital you use this site. I'm sorry if this wasn't advised when you contacted us.
I have tested your line today and it shows you currently have a sync speed of 7.6mbps and a stable connection for 7 days (you may have just noticed some drops, this is from me testing, I'm sorry if you were doing anything at the time).
Just to check, when running the tests, there were no other programs running in the background such as streaming, browsing or anti virus updating?
If you haven't already, please can you have a run through our troubleshooting guides here and raise a fault here. If you let us know once done we can pick this up and investigate further for you.
18-01-2019 5:10 PM
yes i am sure there measured correctly, i used a site called speedofme which downloads a fake file to monitor the download speed and that came back with the same result as other sites but just an update, i am now on hold again trying to get through to the tech part as i am now getting 200kbps download speed and 0 upload with 721 ping, this has been my speeds for the past 2 days
18-01-2019 8:54 PM
Hi @Jordan2703
I can see that you have subsequently spoken to a tech agent who has agreed to send you out a new router.
Can you please let us know once you have received this?
Kind Regards,
MoR
19-01-2019 6:02 PM
yes i will update the results of a new router once tested, i did however follow plusnets suggestions from yesterday by changing the ADSL filter with a new one and that did NOT make any changes to my speed, there is an update on my speed today though, its running around the same 150-200kbps download and 0.1kbps upload with 1024 ping, but ive noticed today that the speed has got so slow that google will no longer load (just keeps attempting to load main page) so i am currently using my pc with mobile hotspot as my data is now faster than my wifi,
Also want to ask what will happen if it turns out to be a technical issue on plusnets side as i have paid every month since i joined and havnt received the speeds as promised?
19-01-2019 6:17 PM
No my speeds is not a result of you checking, i am not getting speed drops i am getting a constant speed of 200kbps and between 3 days ago and when i joined i was getting under 1mbs download speed, i know on your system what it says im getting because they tell me the same result every time i call (strange right) but i am not receiving those speeds, if i was getting those speeds i would be able to stream films with no issue, i would be able to download games with no issue and i would be able to play games without a 1000ping, so whatever it says im getting on your end im not.
and no every program was closed i made sure of that with task manager, and all my games are set to update manually.
The problem is not on my side, as the only thing thats changed since i was with sky is the router and filter that plusnet provided and i was running speeds at 10mbs minimum with sky so its clearly an issue with the product you sent out or something on your side thats not right.
20-01-2019 8:41 PM
Hello @Jordan2703,
Thanks for getting back to us and I am sorry to hear you are experiencing an issue with your service.
We need to locate the cause of the issue and get your connection back to where it should be. Once this has been achieved it is at that point we would look at services you have paid for but not received.
Please let us know how you get on with the new router.
