Plusnet hub constant in disconnection loop
rewerty7777
I have a plusnet problem which has gradually been getting worse,  today,  it has become chronic.  And the most unbelievable thing is that this issue is the EXACT same Plusnet issue I experienced ten years ago in 2013 at a different address with a different router.
The router simply disconnects for an unknown reason,  begins a reconnection attempt,  reconnects successfully,  but that is very short lived before disconnection occurs again and reconnection attempts begin.
This has happened AT LEAST FIFTY times today.   I just tried to raise a ticket but the option is nowhere to be found.
I can't believe this is happening,  I literally left plusnet in 2013 because this issue made my Internet unusable.
I don't have fibre broadband,  this is the slower connection package but the router is very modern plusnet HUB ONE
2 REPLIES 2
Fixes: 378
Re: Plusnet hub constant in disconnection loop
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
willcutforth
Fixes: 113
Hey there @rewerty7777 I can see you contacted the call centre yesterday and spoke to Rizwan! How has it been since?
 Will Cutforth
