Plusnet gateway and DNS problems
- Plusnet gateway and DNS problems
Re: Plusnet gateway and DNS problems
25-05-2021 8:01 PM - edited 25-05-2021 8:02 PM
@Gandalf Has this change resolved the issue btw or is it too soon to tell?
Currently no problems, but I need a several days before I can tell. I'll post with any updates.
25-05-2021 8:04 PM
01-06-2021 3:42 PM
Service solid now for over 7 days, so looks like the change from static to dynamic ip seems to have resolved the issue. How do we proceed now?
01-06-2021 3:49 PM
Thanks for the update @avant-guvnor
I've triggered a static IP to be automatically applied back on your account by re-enabling the broadband firewall you had on.
Can you reboot your router and retest? Let me know how it goes.
01-06-2021 4:36 PM
@Gandalf router rebooted as requested. Now testing...
01-06-2021 4:53 PM
With this problem I have seen two browser windows pointing at the same website work and not work concurrently.
Flushing the device’s DNS cache is a good test to see if this is the problem “in play”.
01-06-2021 5:01 PM
@Townman When the issue occurs ALL devices on my lan (5 Win10 Pro PCs, 3 Android mobile devices and the router itself) exhibit the issue.
01-06-2021 5:06 PM
That needs access via telnet - I will see if I can find the instructions...
01-06-2021 5:14 PM
@Townman When you get the issue, have you inspected the router’s spoofed address list?
If you mean dns server debug spoof list, no, not when the issue has occurs.
02-06-2021 2:03 PM
Problem has returned, for about 2 hours now. Please advise.
02-06-2021 2:12 PM
02-06-2021 2:18 PM - edited 02-06-2021 2:20 PM
@MisterW When it happens again, if you could try an nslookup...
C:\WINDOWS\system32>nslookup bbc.co.uk
Server: dsldevice.lan
Address: fe80::9e97:26ff:fe96:c6e2
DNS request timed out.
timeout was 2 seconds.
*** Request to dsldevice.lan timed-out
C:\WINDOWS\system32>nslookup bbc.co.uk 8.8.8.8
Server: dns.google
Address: 8.8.8.8
Non-authoritative answer:
Addresses: 2a04:4e42::81
2a04:4e42:200::81
2a04:4e42:400::81
2a04:4e42:600::81
151.101.0.81
151.101.64.81
151.101.128.81
151.101.192.81
02-06-2021 2:25 PM
Along side that, what IP address is returned if you PING bbc.co.uk?
02-06-2021 2:33 PM
@Townman Along side that, what IP address is returned if you PING bbc.co.uk?
C:\WINDOWS\system32>ping bbc.co.uk
Ping request could not find host bbc.co.uk. Please check the name and try again.
02-06-2021 2:38 PM - edited 02-06-2021 2:39 PM
Since @avant-guvnor has already said that the tg582 is configured to use Google dns. Then from the nslookup above, one can only conclude that the tg582 is failing to forward dns requests. This is not an unknown problem with the tg582
