Plusnet fibre usage question
- Plusnet fibre usage question
09-11-2012 2:47 PM
Just ordered plusnet extra fibre, I meant to ask on the phone, what speed does it reduce to after you go over your limit (if you set a usage cap on it)?
Message 1 of 5
(927 Views)
4 REPLIES 4
Re: Plusnet fibre usage question
09-11-2012 3:12 PM
Your speed would be set to 256kbps, I'd suggest trying to take advantage of the free usage between midnight and 8am daily to avoid this where possible.
If there's anything else I can help with then give me a nudge.
Message 2 of 5
(447 Views)
09-11-2012 3:59 PM
wow !!!!
that fast eh ?!
I'd recommend not going over your limit mind! or if you do, hire some pigeons, they can carry packets faster than that speed!!
Sounds fair enough though.
that fast eh ?!
Message 3 of 5
(447 Views)
09-11-2012 6:34 PM
Quote from: chrispurvey Your speed would be set to 256kbps, I'd suggest trying to take advantage of the free usage between midnight and 8am daily to avoid this where possible.
This is for the fibre package?
Message 4 of 5
(447 Views)
09-11-2012 6:47 PM
Its so you buy the extra usage at £5/5Gb
I am on my first full month of it and so far keeping to with in the limits, I limit my "normal" downloads to 2Mb (200Kb/s) and full speed over night. However if you are streaming a lot of stuff you may come a cropper.
Message 5 of 5
(447 Views)
